Ga door naar hoofdinhoud
Nabi Jr Motherboard Replacement
Wat je nodig hebt
    1. Nabi Jr Motherboard Replacement, Rear Case: stap 1, afbeelding 1 van 1
      • Remove the red rubber case from the device. This should come off with ease.
      Vraag FixBot
      Voeg opmerking toe
    2. Nabi Jr Motherboard Replacement: stap 2, afbeelding 1 van 1
      • Turn the device so the screen is facing away from you.
      • Using a philips head, size #00, screwdriver, remove the screws in each corner of the plastic casing.(total of 4 screws)
      Vraag FixBot
      Voeg opmerking toe
    3. Nabi Jr Motherboard Replacement: stap 3, afbeelding 1 van 1
      • Remove the device casing using a small plastic pry bar.
      • This might take a little bit of force to accomplish, don't be afraid to go at it with a little gusto.
      Vraag FixBot
      Voeg opmerking toe
    4. Nabi Jr Motherboard Replacement: stap 4, afbeelding 1 van 1
      • After loosening the back cover, remove it from the device so you can get at the innards.
      Vraag FixBot
      Voeg opmerking toe
    1. Nabi Jr Motherboard Replacement, Motherboard: stap 5, afbeelding 1 van 1
      • Use the Philips #00 screwdriver to remove the 5 screws from the motherboard
      Vraag FixBot
      Voeg opmerking toe
    2. Nabi Jr Motherboard Replacement: stap 6, afbeelding 1 van 1
      • De-solder the grey wire from motherboard
      Vraag FixBot
      Voeg opmerking toe
    3. Nabi Jr Motherboard Replacement: stap 7, afbeelding 1 van 1
      Gereedschap gebruikt in deze stap:
      • Use tweezers to peel off all yellow tape from the motherboard
      • Yellow tape is used in all locations where there is ribbon cable present.
      Vraag FixBot
      Voeg opmerking toe
    4. Nabi Jr Motherboard Replacement: stap 8, afbeelding 1 van 2 Nabi Jr Motherboard Replacement: stap 8, afbeelding 2 van 2
      • Remove all three ribbon cables from the motherboard by lifting up the locking tabs.
      • Pull black locking tabs up in opposite direction of ribbon cable to remove.
      • Use tweezers to pull the ribbon cable out of the locking tab's slot
      Vraag FixBot
      Voeg opmerking toe
    5. Nabi Jr Motherboard Replacement: stap 9, afbeelding 1 van 2 Nabi Jr Motherboard Replacement: stap 9, afbeelding 2 van 2
      • Lift motherboard to separate it the from the case shell.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
Kaila Joy
86 Reputatie
2 handleidingen geschreven
UMass Dartmouth, Team 4-3, Vijaybhaskar Spring 2015 Lid van UMass Dartmouth, Team 4-3, Vijaybhaskar Spring 2015
UMASSD-VIJAYBHASKAR-S15S4G3
3 Leden
12 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 17
Altijd: 1,443
