Wat je nodig hebt
Remove the red rubber case from the device. This should come off with ease.
If all the steps were followed correctly, the device should be fully closed and ready to go
4 andere personen hebben deze handleiding voltooid.
7Gids Commentaar
Thank you for sharing the idea ,but I need that NABI JR battery. So ,where from I can purchase it .
I have seen them on ebay but it's easier to find a Nabi 2 battery on ebay. The Nabi 2 battery is quite a bit larger but with a very minor mod to the Nabi Jr. the Nabi 2 battery will fit and give you a much longer run time from a single charge.
My old Nabi jr battery is a plug in with 2 reds 1 white and 2 black wires. My new Cameron sino battery is blue green red yellow black. What is the order to resolder them.
I have the same problem with the problem of the replacement battery not having the same wiring configuration or plug. Did you ever get this resolved?
