Deze versie kan foutieve bewerkingen bevatten. Schakel over naar de recentste gecontroleerde momentopname.
Wat je nodig hebt
Deze stap is niet vertaald. Help het te vertalen
Use the plastic opening tool to carefully lift the rubber stops in each corner.
Unscrew the 4 11.8 mm T-8 Torx screws from each corner of the device.
Lift the lower case straight up from the rest of the router.
Remove the clear plastic casing by lifting it straight up from the router.
Separate the motherboard from the top shell by lifting it straight up from the router.
Turn the motherboard so that the top is facing upwards.
Place the motherboard on a clean flat surface.
Turn the motherboard so that the bottom is facing upwards.
Locate the two soldered contacts for each capacitor.
Desolder the soldered connections between the capacitors and the motherboard, and pull the capacitor from the motherboard.
Één andere persoon heeft deze handleiding voltooid.
Één opmerking
my router NETGEAR WNR 612 WIFI LED NOT GLOWING PLEASE HLP ME IN REPAIRING
