Ga door naar hoofdinhoud
NABI XD Screen Replacement
Wat je nodig hebt
    1. NABI XD Screen Replacement, Rear panel: stap 1, afbeelding 1 van 2 NABI XD Screen Replacement, Rear panel: stap 1, afbeelding 2 van 2
      • Use the plastic opening tool at the top left corner seam, then pry the corner apart.
      Vraag FixBot
      Voeg opmerking toe
    2. NABI XD Screen Replacement: stap 2, afbeelding 1 van 1
      • Next slide the plastic opening tool across the sides of the Nabi. It will slowly open.
      • There are small plastic clips that need to be release. Gently apply outwards pressure until the clips give.
      • Go around the NABI XD and separate the rear panel from the device.
      Vraag FixBot
      Voeg opmerking toe
    1. NABI XD Screen Replacement, Battery: stap 3, afbeelding 1 van 2 NABI XD Screen Replacement, Battery: stap 3, afbeelding 2 van 2
      • Place your fingernails on both sides of the connector and pull it straight back away from the holder.
      Vraag FixBot
      Voeg opmerking toe
    2. NABI XD Screen Replacement: stap 4, afbeelding 1 van 1
      • Battery is glued to the base, lift carefully.
      • To remove battery, lift the battery up from the motherboard.
      Vraag FixBot
      Voeg opmerking toe
    1. NABI XD Screen Replacement, Charging port: stap 5, afbeelding 1 van 2 NABI XD Screen Replacement, Charging port: stap 5, afbeelding 2 van 2
      Gereedschap gebruikt in deze stap:
      • Remove the two 4mm Phillips screws with the PH#0 screwdriver.
      • Disconnect the left (L) speaker wire from the charging port by grabbing it on both sides with the tweezers and pulling straight back.
      Vraag FixBot
      Voeg opmerking toe
    2. NABI XD Screen Replacement: stap 6, afbeelding 1 van 1
      • Use your fingernails or a spudger to flip up the small retaining flap, then pull the ribbon straight back to remove
      • Lift the charging port from the NABI XD.
      Vraag FixBot
      Voeg opmerking toe
    1. NABI XD Screen Replacement, Motherboard: stap 7, afbeelding 1 van 3 NABI XD Screen Replacement, Motherboard: stap 7, afbeelding 2 van 3 NABI XD Screen Replacement, Motherboard: stap 7, afbeelding 3 van 3
      • To remove the marked ribbons, use your fingernails or a spudger to lift up small tab
      • Use the Precision Tweezers to gently pull the ribbons straight out of the connectors.
      • You need to remove 4 ribbons
      Vraag FixBot
      Voeg opmerking toe
    2. NABI XD Screen Replacement: stap 8, afbeelding 1 van 3 NABI XD Screen Replacement: stap 8, afbeelding 2 van 3 NABI XD Screen Replacement: stap 8, afbeelding 3 van 3
      • Disconnect the camera by lifting the ribbon straight up. Also disconnect the remaining ribbon by lifting up gently.
      • To disconnect antenna wire, use the tweezers to pry connector straight from the board.
      Vraag FixBot
      Voeg opmerking toe
    3. NABI XD Screen Replacement: stap 9, afbeelding 1 van 2 NABI XD Screen Replacement: stap 9, afbeelding 2 van 2
      • Disconnect the Right speaker by grabbing the wire head by its sides and pulling it back from the connector.
      Vraag FixBot
      Voeg opmerking toe
    4. NABI XD Screen Replacement: stap 10, afbeelding 1 van 2 NABI XD Screen Replacement: stap 10, afbeelding 2 van 2
      • Remove the four 4mm Phillips screws with the PH#0 screwdriver.
      Vraag FixBot
      Voeg opmerking toe
    5. NABI XD Screen Replacement: stap 11, afbeelding 1 van 1
      • Lift the motherboard up away from the Nabi XD.
      Vraag FixBot
      Voeg opmerking toe
    1. NABI XD Screen Replacement, Speakers: stap 12, afbeelding 1 van 3 NABI XD Screen Replacement, Speakers: stap 12, afbeelding 2 van 3 NABI XD Screen Replacement, Speakers: stap 12, afbeelding 3 van 3
      • Right (R) speaker removal:
      • Remove one 4mm Phillips screw.
      • Use the metal spudger to separate the speaker from the frame.
      • The speaker is glued to the Nabi XD it will require some force to separate them.
      Vraag FixBot
      Voeg opmerking toe
    2. NABI XD Screen Replacement: stap 13, afbeelding 1 van 2 NABI XD Screen Replacement: stap 13, afbeelding 2 van 2
      • Remove the left (L) speaker wire from the frame by pulling it to the side and up.
      • The wire in this step, is connected to the charging port. Removing it, is shown in detail on step 6.
      Vraag FixBot
      Voeg opmerking toe
    3. NABI XD Screen Replacement: stap 14, afbeelding 1 van 3 NABI XD Screen Replacement: stap 14, afbeelding 2 van 3 NABI XD Screen Replacement: stap 14, afbeelding 3 van 3
      • Left (L) speaker removal:
      • Remove two 4mm Phillips screws.
      Vraag FixBot
      Voeg opmerking toe
    1. NABI XD Screen Replacement, Screen: stap 15, afbeelding 1 van 3 NABI XD Screen Replacement, Screen: stap 15, afbeelding 2 van 3 NABI XD Screen Replacement, Screen: stap 15, afbeelding 3 van 3
      • The ribbons are glued to the frame so gently lift them up without ripping them.
      • Lightly lift the marked wires and ribbons from the frame by gently pulling them in the direction of the arrows and up.
      • Remove five 4mm Phillips screws from the frame.
      Vraag FixBot
      Voeg opmerking toe
    2. NABI XD Screen Replacement: stap 16, afbeelding 1 van 2 NABI XD Screen Replacement: stap 16, afbeelding 2 van 2
      • Use the Plastic Opening tools to lift the frame up.
      • The ribbons need to be detangled from the frame while you are lifting it up.
      • Do not yank the frame away from the Nabi XD it is connect to it by a ribbon. Gently lift.
      Vraag FixBot
      Voeg opmerking toe
    3. NABI XD Screen Replacement: stap 17, afbeelding 1 van 2 NABI XD Screen Replacement: stap 17, afbeelding 2 van 2
      • Lift the screen up with the black spudger.
      • Lift the frame up slowly and place it to the side.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Marissa Schiereck
638 Reputatie
6 handleidingen geschreven
USF Tampa, Team 17-2, Blackwell Fall 2016 Lid van USF Tampa, Team 17-2, Blackwell Fall 2016
USFT-BLACKWELL-F16S17G2
3 Leden
12 handleidingen geschreven
1Gids Commentaar
Will the screen from an A or C model work with a B model?
Kevin Fifer - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 9
Afgelopen 30 dagen: 27
Altijd: 1,091
