Ga door naar hoofdinhoud
Munchkinz Motherboard Replacement
Wat je nodig hebt
    1. Munchkinz Motherboard Replacement, Opening Device: stap 1, afbeelding 1 van 1
      • Insert spudger into the USB Micro slot and pry the case apart.
      • Be careful not to go too deep and bend the prong inside the Micro USB port.
      Vraag FixBot
      Voeg opmerking toe
    2. Munchkinz Motherboard Replacement, Pry Device Apart: stap 2, afbeelding 1 van 2 Munchkinz Motherboard Replacement, Pry Device Apart: stap 2, afbeelding 2 van 2
      • Slide the wide plastic opening tool across the seem, separating it if you can't pry the device open using just the spudger.
      • Gently separate the case so none of the cords inside are disconnected
      Vraag FixBot
      Voeg opmerking toe
    3. Munchkinz Motherboard Replacement, Separated Device: stap 3, afbeelding 1 van 1
      • After prying the device apart, it should look like this.
      Vraag FixBot
      Voeg opmerking toe
    1. Munchkinz Motherboard Replacement, Pry Camera: stap 4, afbeelding 1 van 1
      • Use the slim plastic opening tool to pry the camera from its initial position.
      Vraag FixBot
      Voeg opmerking toe
    2. Munchkinz Motherboard Replacement, Disconnect Ribbon: stap 5, afbeelding 1 van 1
      Gereedschap gebruikt in deze stap:
      • Use the precision tweezers to gently disconnect the camera ribbon that is connected to the motherboard.
      Vraag FixBot
      Voeg opmerking toe
    1. Munchkinz Motherboard Replacement, Pry Speaker: stap 6, afbeelding 1 van 2 Munchkinz Motherboard Replacement, Pry Speaker: stap 6, afbeelding 2 van 2
      • Use the slim plastic opening tool to remove the speaker from its position on the case.
      Vraag FixBot
      Voeg opmerking toe
    2. Munchkinz Motherboard Replacement, Locate Wires: stap 7, afbeelding 1 van 1
      • Locate the red and black wires that connect the speaker to the motherboard.
      Vraag FixBot
      Voeg opmerking toe
    3. Munchkinz Motherboard Replacement, Solder Wires: stap 8, afbeelding 1 van 1
      • Un-solder the red and black speaker wires that are connected to the motherboard
      Vraag FixBot
      Voeg opmerking toe
    1. Munchkinz Motherboard Replacement, Volume Button: stap 9, afbeelding 1 van 1
      • Remove the plastic volume button.
      Vraag FixBot
      Voeg opmerking toe
    2. Munchkinz Motherboard Replacement, Unscrew Module: stap 10, afbeelding 1 van 1
      • Remove the two screws that hold the volume button assembly in place.
      Vraag FixBot
      Voeg opmerking toe
    3. Munchkinz Motherboard Replacement, Solder Module Wires: stap 11, afbeelding 1 van 1
      • Un-solder the yellow, red, and black wires that connect the volume module to the motherboard.
      Vraag FixBot
      Voeg opmerking toe
    1. Munchkinz Motherboard Replacement, Removing battery: stap 12, afbeelding 1 van 3 Munchkinz Motherboard Replacement, Removing battery: stap 12, afbeelding 2 van 3 Munchkinz Motherboard Replacement, Removing battery: stap 12, afbeelding 3 van 3
      • Use the wide plastic opening tool to slowly pry each side of the battery up.
      • Be careful not to bend the battery too much.
      Vraag FixBot
      Voeg opmerking toe
    2. Munchkinz Motherboard Replacement, Remove battery completely: stap 13, afbeelding 1 van 1
      • Use the Soldering Iron to disconnect the each cable.
      Vraag FixBot
      Voeg opmerking toe
    1. Munchkinz Motherboard Replacement, Remove Tape: stap 14, afbeelding 1 van 1
      • Remove black tape covering any of the ribbons that have it.
      Vraag FixBot
      Voeg opmerking toe
    2. Munchkinz Motherboard Replacement, Remove Ribbons: stap 15, afbeelding 1 van 1
      • Pull the ribbons out from the plugs.
      Vraag FixBot
      Voeg opmerking toe
    3. Munchkinz Motherboard Replacement, Remove Camera/Hidden Screw: stap 16, afbeelding 1 van 1
      • After removing the camera, remove the hidden screw.
      Vraag FixBot
      Voeg opmerking toe
    4. Munchkinz Motherboard Replacement, Remove Screws: stap 17, afbeelding 1 van 1
      • Remove screws located on the opposite side of the battery.
      Vraag FixBot
      Voeg opmerking toe
    5. Munchkinz Motherboard Replacement, Lift: stap 18, afbeelding 1 van 1
      • Carefully lift up the motherboard. Your accessory parts such as battery, speaker, volume button assembly, and camera wires will be disconnected, not connected, like in this picture.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
Austin Oliveira
204 Reputatie
2 handleidingen geschreven
UW Tacoma, Team 3-6, Rose Winter 2015 Lid van UW Tacoma, Team 3-6, Rose Winter 2015
UWT-ROSE-W15S3G6
3 Leden
14 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 9
Afgelopen 30 dagen: 27
Altijd: 524
