Ga door naar hoofdinhoud
Munchkinz LCD Assembly
Wat je nodig hebt
    1. Munchkinz LCD Assembly, Opening Device: stap 1, afbeelding 1 van 1
      • Insert spudger into the USB Micro slot and pry the case apart.
      • Be careful not to go too deep and bend the prong inside the Micro USB port.
      Vraag FixBot
      Voeg opmerking toe
    2. Munchkinz LCD Assembly, Pry Device Apart: stap 2, afbeelding 1 van 2 Munchkinz LCD Assembly, Pry Device Apart: stap 2, afbeelding 2 van 2
      • Slide the wide plastic opening tool across the seem, separating it if you can't pry the device open using just the spudger.
      • Gently separate the case so none of the cords inside are disconnected
      Vraag FixBot
      Voeg opmerking toe
    3. Munchkinz LCD Assembly, Separated Device: stap 3, afbeelding 1 van 1
      • After prying the device apart, it should look like this.
      Vraag FixBot
      Voeg opmerking toe
    1. Munchkinz LCD Assembly, Remove Speaker: stap 4, afbeelding 1 van 1
      • Use the plastic opening tool to remove the speaker from the casing.
      Vraag FixBot
      Voeg opmerking toe
    2. Munchkinz LCD Assembly, Pry Camera: stap 5, afbeelding 1 van 1
      • Use the slim plastic opening tool to pry the camera from its position.
      Vraag FixBot
      Voeg opmerking toe
    3. Munchkinz LCD Assembly, Unscrew Volume Module: stap 6, afbeelding 1 van 2 Munchkinz LCD Assembly, Unscrew Volume Module: stap 6, afbeelding 2 van 2
      • Unscrew the two screws that hold the volume module to the casing.
      Vraag FixBot
      Voeg opmerking toe
    4. Munchkinz LCD Assembly, Pry Battery: stap 7, afbeelding 1 van 1
      • Use the plastic opening tool to slowly pry each side of the battery up.
      • Be careful not to bend the battery too much.
      Vraag FixBot
      Voeg opmerking toe
    5. Munchkinz LCD Assembly, Remove Ribbons: stap 8, afbeelding 1 van 1
      • Remove the two highlighted ribbons from the motherboard.
      Vraag FixBot
      Voeg opmerking toe
    6. Munchkinz LCD Assembly, Remove Screws: stap 9, afbeelding 1 van 1
      • Use the screw driver to remove the highlighted screws.
      Vraag FixBot
      Voeg opmerking toe
    7. Munchkinz LCD Assembly, Remove Hidden Screw: stap 10, afbeelding 1 van 1
      • Use the plastic opening tool to hold the camera ribbon back.
      • Unscrew the screw under ribbon with the screw driver.
      Vraag FixBot
      Voeg opmerking toe
    8. Munchkinz LCD Assembly, Remove Motherboard: stap 11, afbeelding 1 van 1
      • Remove the motherboard from the casing.
      Vraag FixBot
      Voeg opmerking toe
    9. Munchkinz LCD Assembly, Pry Up Screen: stap 12, afbeelding 1 van 3 Munchkinz LCD Assembly, Pry Up Screen: stap 12, afbeelding 2 van 3 Munchkinz LCD Assembly, Pry Up Screen: stap 12, afbeelding 3 van 3
      • Oriented the device so the battery is closest to the user.
      • Use the plastic opening tool to pry the clips up to release LCD screen.
      • Gently lift the northern end of the screen and slide it out horizontally.
      Vraag FixBot
      Voeg opmerking toe
    10. Munchkinz LCD Assembly, Solder LCD Wires: stap 13, afbeelding 1 van 1
      • Unsolder the black and red LCD wires.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
Één andere persoon heeft deze handleiding voltooid.
David Wood
440 Reputatie
4 handleidingen geschreven
UW Tacoma, Team 3-6, Rose Winter 2015 Lid van UW Tacoma, Team 3-6, Rose Winter 2015
UWT-ROSE-W15S3G6
3 Leden
14 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 23
Altijd: 650
