Ga door naar hoofdinhoud
Munchkin Mozart Magic Cube Light Replacement
Wat je nodig hebt
  1. Munchkin Mozart Magic Cube Light Replacement, Face plate: stap 1, afbeelding 1 van 2 Munchkin Mozart Magic Cube Light Replacement, Face plate: stap 1, afbeelding 2 van 2
    • Remove two 6 mm Phillips #2 screws on either side of the On/Off Plate.
  2. Munchkin Mozart Magic Cube Light Replacement: stap 2, afbeelding 1 van 1
    • Remove the On/Off switch plate and save the screws so you can use them later to put the plate back on.
  3. Munchkin Mozart Magic Cube Light Replacement: stap 3, afbeelding 1 van 1
    • Gently pull out the battery cartridge and if needed, replace the batteries with 3 AA alkaline batteries.
  4. Munchkin Mozart Magic Cube Light Replacement: stap 4, afbeelding 1 van 1
    • Starting with the yellow face, insert the metal spudger between the yellow face and the white frame, prying the frame apart.
  5. Munchkin Mozart Magic Cube Light Replacement: stap 5, afbeelding 1 van 1
    • Insert the metal spudger in the space created by the plastic opening tool between the frame and face of the cube.
    • Pry the cube face from the frame.
  6. Munchkin Mozart Magic Cube Light Replacement: stap 6, afbeelding 1 van 1
    • After removing the square plates, you can unscrew the screws underneath.
    • Remove four 6 mm Phillips #2 screws, located on the sides.
  7. Munchkin Mozart Magic Cube Light Replacement: stap 7, afbeelding 1 van 1
    • Remove the rubber corners by simply pulling them off.
  8. Munchkin Mozart Magic Cube Light Replacement, Frame Removal: stap 8, afbeelding 1 van 1
    • Remove twenty-four 6 mm Phillips #2 from all 6 sides.
    • Once the screws are removed, gently pull apart the frame.
  9. Munchkin Mozart Magic Cube Light Replacement, Light: stap 9, afbeelding 1 van 1
    • Flip the frame over so that green motherboard over so that the LED is face down and the brown side of the motherboard is face up.
    • Use the Jimmy to remove the glue connecting the motherboard to the white frame.
  10. Munchkin Mozart Magic Cube Light Replacement: stap 10, afbeelding 1 van 1
    • Slide the motherboard out of the frame.
  11. Munchkin Mozart Magic Cube Light Replacement: stap 11, afbeelding 1 van 1
    • Use the soldering iron to desolder the LED by applying heat to the half sphere like connections.
    • For soldering instructions please see this additional guide Hoe moet je (de-)solderen?
  12. Munchkin Mozart Magic Cube Light Replacement: stap 12, afbeelding 1 van 1
    • Take the new LED and solder the two legs back to the motherboard.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Nikolas Soulandros
291 Reputatie
2 handleidingen geschreven
USF Tampa, Team 1-4, Sullivan Fall 2015 Lid van USF Tampa, Team 1-4, Sullivan Fall 2015
USFT-SULLIVAN-F15S1G4
4 Leden
14 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 10
Altijd: 486
