Ga door naar hoofdinhoud
Motorola syn1654A Speaker Module Replacement
Wat je nodig hebt
  1. Motorola syn1654A Speaker Module Replacement, Speaker Module: stap 1, afbeelding 1 van 2 Motorola syn1654A Speaker Module Replacement, Speaker Module: stap 1, afbeelding 2 van 2
    • See the speaker replacement guide and follow steps 1 and 2.
  2. Motorola syn1654A Speaker Module Replacement: stap 2, afbeelding 1 van 1
    • Use the T6 torx screwdriver to remove the seven screws located around the headphone cover and place the screws in a safe place.
    • To avoid stripping screws, be sure to use the right drill bit oriented perpendicular to the face of the screw.
  3. Motorola syn1654A Speaker Module Replacement: stap 3, afbeelding 1 van 1
    • Carefully lift the speaker out of its housing while leaving all wires connected.
  4. Motorola syn1654A Speaker Module Replacement: stap 4, afbeelding 1 van 1
    • Lift the module out of the headphone cup, leaving all wires attached.
    • Clip the two wires circled in orange.
    • Now that the speaker is free set it aside.
    • Clip the two wires circled in yellow.
    • Replace speaker module and solder it to the two wires circled in orange.
    • Now solder the speaker wires (circled in yellow) back to the module.
    • For soldering see the ifixit soldering guide: Hoe moet je (de-)solderen?
Conclusie
Ben
104 Reputatie
1 Handleiding geschreven
Michigan Tech, Team 5-1, Lauer Spring 2014 Lid van Michigan Tech, Team 5-1, Lauer Spring 2014
MTU-LAUER-S14S5G1
2 Leden
3 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 12
Altijd: 252
