Ga door naar hoofdinhoud
Motorola syn1654A Microphone Replacement
Wat je nodig hebt
  1. Motorola syn1654A Microphone Replacement, Microphone: stap 1, afbeelding 1 van 2 Motorola syn1654A Microphone Replacement, Microphone: stap 1, afbeelding 2 van 2
    • Remove star head screw from above base of the microphone with T6 Torx Screwdriver.
    • To prevent stripping, use an appropriate bit and ensure screwdriver is oriented perpendicular to the face of the screw.
  2. Motorola syn1654A Microphone Replacement: stap 2, afbeelding 1 van 1
    • To expose the next screw, peel foam cover from the base toward the end of microphone.
    • Remove screw with screwdriver and place in a safe location.
  3. Motorola syn1654A Microphone Replacement: stap 3, afbeelding 1 van 3 Motorola syn1654A Microphone Replacement: stap 3, afbeelding 2 van 3 Motorola syn1654A Microphone Replacement: stap 3, afbeelding 3 van 3
    • With Screws removed, remove the microphone from foam and plastic cover to be inspected.
    • If the microphone is corroded or wires are frayed, it must be replaced.
  4. Motorola syn1654A Microphone Replacement: stap 4, afbeelding 1 van 1
    • Clip both wires to remove defective microphone.
    • Be sure to clip as close to the base of the microphone as possible in order to have enough wire for the new microphone.
    • Align wires with corresponding pads on new microphone and solder in place.
    • For soldering, see the Ifixit soldering guide: Hoe moet je (de-)solderen?
Conclusie
Één andere persoon heeft deze handleiding voltooid.
John Ware
325 Reputatie
2 handleidingen geschreven
Michigan Tech, Team 5-1, Lauer Spring 2014 Lid van Michigan Tech, Team 5-1, Lauer Spring 2014
MTU-LAUER-S14S5G1
2 Leden
3 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 13
Altijd: 364
