Ga door naar hoofdinhoud
Motorola syn1654A Headphone Speaker Replacement
Wat je nodig hebt
  1. Motorola syn1654A Headphone Speaker Replacement, Headphone Speaker: stap 1, afbeelding 1 van 1
    • Make sure the headphones are off and unplugged from any devices.
    • Remove leather headphone cushion by pulling edge towards middle of headphone.
    • It should slip off the device.
  2. Motorola syn1654A Headphone Speaker Replacement: stap 2, afbeelding 1 van 1
    • Carefully peel back foam pad to prevent tearing.
    • It is glued at both the top and bottom.
  3. Motorola syn1654A Headphone Speaker Replacement: stap 3, afbeelding 1 van 1
    • Use the T6 torx screwdriver to remove the three screws holding the speaker in place.
    • To avoid stripping screws, be sure to use the right screw bit oriented perpendicular to the face of the screw.
  4. Motorola syn1654A Headphone Speaker Replacement: stap 4, afbeelding 1 van 1
    • With the speaker removed from the speaker module, clip the black and white wires on the back of the speaker, as shown.
    • Solder wires onto corresponding pads of replacement speaker.
    • For soldering see the ifixit soldering guide: Hoe moet je (de-)solderen?
Conclusie
John Ware
325 Reputatie
2 handleidingen geschreven
Michigan Tech, Team 5-1, Lauer Spring 2014 Lid van Michigan Tech, Team 5-1, Lauer Spring 2014
MTU-LAUER-S14S5G1
2 Leden
3 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 9
Afgelopen 30 dagen: 12
Altijd: 398
