Ga door naar hoofdinhoud
Motorola i710 Microphone Replacement
Wat je nodig hebt
  1. Motorola i710 Microphone Replacement, Battery Cover: stap 1, afbeelding 1 van 2 Motorola i710 Microphone Replacement, Battery Cover: stap 1, afbeelding 2 van 2
    • Slide the cover release button towards the bottom of the phone
    • Once the battery cover pops up, slide the cover towards the top of the phone and lift up.
    Vraag FixBot
    Voeg opmerking toe
  2. Motorola i710 Microphone Replacement, Battery: stap 2, afbeelding 1 van 1
    • Push the battery towards the top of the phone and lift up.
    Vraag FixBot
    Voeg opmerking toe
  3. Motorola i710 Microphone Replacement, Back Casing: stap 3, afbeelding 1 van 3 Motorola i710 Microphone Replacement, Back Casing: stap 3, afbeelding 2 van 3 Motorola i710 Microphone Replacement, Back Casing: stap 3, afbeelding 3 van 3
    • With a T5 screwdriver, unscrew the four T5 sized screws that hold the case back cover onto the rest of the case.
    • Remove the plastic case back cover by gently pulling it away from the body of the phone, starting at one edge and working your way down to the other.
    Vraag FixBot
    Voeg opmerking toe
  4. Motorola i710 Microphone Replacement, Microphone: stap 4, afbeelding 1 van 3 Motorola i710 Microphone Replacement, Microphone: stap 4, afbeelding 2 van 3 Motorola i710 Microphone Replacement, Microphone: stap 4, afbeelding 3 van 3
    Gereedschap gebruikt in deze stap:
    • Lift the circuit board away from the case of the phone, being careful not to break the wire that goes up into the hinge. This will give you access to the microphone.
    • The microphone sits just below the keys on the front cover molding.
    • Grasp the microphone with tweezers and lift it out of the front cover.
    Vraag FixBot
    Voeg opmerking toe
Conclusie
Carson Meena
16 Reputatie
5 handleidingen geschreven
Clemson, Team 14-2, Benson Fall 2012 Lid van Clemson, Team 14-2, Benson Fall 2012
CLEM-BENSON-F12S14G2
4 Leden
41 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 12
Afgelopen 30 dagen: 41
Altijd: 642
