Ga door naar hoofdinhoud
Motorola i710 LCD Screen Replacement
Wat je nodig hebt
  1. Motorola i710 LCD Screen Replacement, Battery Cover: stap 1, afbeelding 1 van 2 Motorola i710 LCD Screen Replacement, Battery Cover: stap 1, afbeelding 2 van 2
    • Slide the cover release button towards the bottom of the phone
    • Once the battery cover pops up, slide the cover towards the top of the phone and lift up.
    Vraag FixBot
    Voeg opmerking toe
  2. Motorola i710 LCD Screen Replacement, Battery: stap 2, afbeelding 1 van 1
    • Push the battery towards the top of the phone and lift up.
    Vraag FixBot
    Voeg opmerking toe
  3. Motorola i710 LCD Screen Replacement, LCD Screen Cover: stap 3, afbeelding 1 van 3 Motorola i710 LCD Screen Replacement, LCD Screen Cover: stap 3, afbeelding 2 van 3 Motorola i710 LCD Screen Replacement, LCD Screen Cover: stap 3, afbeelding 3 van 3
    • Although the lower half of the phone in these images has been disassembled, it is not necessary for removing the LCD screen.
    • With the help of plastic opening tools, remove the i710 name plate and Motorola logo from the backside of the phone.
    • The four screws holding the upper half of the phone together should now be visible.
    Vraag FixBot
    Voeg opmerking toe
  4. Motorola i710 LCD Screen Replacement: stap 4, afbeelding 1 van 2 Motorola i710 LCD Screen Replacement: stap 4, afbeelding 2 van 2
    • With a H1.5 screwdriver, unscrew the four H1.5 sized screws from the back of the phone.
    • Flip the phone onto its back and, with the help of a plastic opening tool, remove the metal speaker cover that is above the LCD screen.
    Vraag FixBot
    Voeg opmerking toe
  5. Motorola i710 LCD Screen Replacement: stap 5, afbeelding 1 van 3 Motorola i710 LCD Screen Replacement: stap 5, afbeelding 2 van 3 Motorola i710 LCD Screen Replacement: stap 5, afbeelding 3 van 3
    • Slide a plastic opening tool along the edge of the LCD Screen Cover to separate the cover from the phone casing. Apply a small amount of force towards the cover if necessary.
    • The LCD screen should now be completely separated from the phone.
    Vraag FixBot
    Voeg opmerking toe
  6. Motorola i710 LCD Screen Replacement, LCD Screen: stap 6, afbeelding 1 van 3 Motorola i710 LCD Screen Replacement, LCD Screen: stap 6, afbeelding 2 van 3 Motorola i710 LCD Screen Replacement, LCD Screen: stap 6, afbeelding 3 van 3
    • Use a spudger to detach the ribbon cable connecting the the LCD screen to the rest of the phone.
    • The TFT LCD screen will now lift out from the phone casing.
    • Be careful not to break the speaker's ribbon cable that sits behind the LCD Screen.
    Vraag FixBot
    Voeg opmerking toe
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Carson Meena
16 Reputatie
5 handleidingen geschreven
Clemson, Team 14-2, Benson Fall 2012 Lid van Clemson, Team 14-2, Benson Fall 2012
CLEM-BENSON-F12S14G2
4 Leden
17 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 12
Afgelopen 30 dagen: 45
Altijd: 758
