Inleiding
Removing the speaker requires the removal of the motherboard, which requires nearly a full dis-assembly of the phone.
Wat je nodig hebt
Place thumb on the rubber tab on the lower back of the phone.
Push away from the phone to release back panel.
Pull antenna up, away from the phone, to reveal two of six screws.
Grab the tab at the bottom of the metal plate, and pull to remove the plate from the phone.
Slightly bend the phone frame to expose microphone protrusion.
Gently remove microphone using your fingers.
