Wat je nodig hebt
Pick up the cell phone with the back facing towards you.
Push down on the silver tab located at the top center of the back of the Motorola W490 cellphone.
While pushing down on the silver tab, slide the back cover towards the silver tab. Remove the back cover.
Remove the battery by pulling the battery from the top corners labeled "Pull Here" located on either side of the top of the battery.
Set the battery aside.
After taking out the battery, locate four star-shaped 5.4 mm T6 screws on top and middle of the rear of the phone. Indicated by the red circles.
Remove all the screws using the Torx T6 Screwdriver.
Identify the flex cable attachment. Indicated in a red square.
Detach the bottom half of the flex cable, pop it off of the circuit board.
Pick up the loosened circuit board from the phone and set aside.
Use the blue plastic opening tool to pry off all four of the rubber stickers from the upper inside face.
Use the Torx T5 screwdriver to remove the four 5.4 mm screws from the upper inner face.
Remove the other end of the flex cable from the LCD board.
Pull the cable through the phone casing hinge and remove it.
2Gids Commentaar
How the !@#$ do you get the new flex cable in??? Id about anybody else, but mine was snapped in half when I opened it, thus, I was unable to see the original assembly... HELP???? Please??
