Ga door naar hoofdinhoud
Motorola Talkabout FV700R Front Faceplate Replacement
Wat je nodig hebt
  1. Motorola Talkabout FV700R Front Faceplate Replacement, Battery: stap 1, afbeelding 1 van 1
    • Remove the back battery cover by pressing the tab to the left, and lifting.
    • A small screwdriver can aid this process.
  2. Motorola Talkabout FV700R Front Faceplate Replacement: stap 2, afbeelding 1 van 1
    • Remove the batteries currently in the radio.
    • When you're ready to add new batteries, place Ni-MH or AAA replacement batteries in the specified slots.
    • The orientation of the batteries is specified in the battery compartment.
  3. Motorola Talkabout FV700R Front Faceplate Replacement, Volume Knob: stap 3, afbeelding 1 van 1
    • Turn the Volume knob to the off position.
  4. Motorola Talkabout FV700R Front Faceplate Replacement: stap 4, afbeelding 1 van 2 Motorola Talkabout FV700R Front Faceplate Replacement: stap 4, afbeelding 2 van 2
    • Firmly grasp and pull back on the volume knob. The knob should come off smoothly.
    • This may require some twisting and force.
  5. Motorola Talkabout FV700R Front Faceplate Replacement, Front Faceplate: stap 5, afbeelding 1 van 1
    • Remove the four 3 millimeter T6 Torx screws from the front of the radio.
  6. Motorola Talkabout FV700R Front Faceplate Replacement: stap 6, afbeelding 1 van 2 Motorola Talkabout FV700R Front Faceplate Replacement: stap 6, afbeelding 2 van 2
    • Remove the four 3 millimeter T8 Torx screws from the back of the radio.
  7. Motorola Talkabout FV700R Front Faceplate Replacement: stap 7, afbeelding 1 van 3 Motorola Talkabout FV700R Front Faceplate Replacement: stap 7, afbeelding 2 van 3 Motorola Talkabout FV700R Front Faceplate Replacement: stap 7, afbeelding 3 van 3
    • Gently open the backplate of the radio. Use a flathead screwdriver to slowly pry apart the two sides.
    • Be careful, as the antenna is still attached. Pulling the two sides apart too quickly could break the antenna.
  8. Motorola Talkabout FV700R Front Faceplate Replacement: stap 8, afbeelding 1 van 2 Motorola Talkabout FV700R Front Faceplate Replacement: stap 8, afbeelding 2 van 2
    • Gently pull the circuit board away from the front faceplate.
    • Be careful not to tug the wire connecting the circuit board to the speaker, as it is still attached to the faceplate.
    • Do not touch the the button contacts on the circuit board (the button contacts are shown in the red box of the second picture). This can cause long-term damage to the radio unless you properly clean them (see Repairing Motorola TALKABOUT FV700 Two Way Radio Button Contacts Guide).
Conclusie
Jack Harrison
188 Reputatie
1 Handleiding geschreven
Clemson, Team 6-4, Benson Spring 2014 Lid van Clemson, Team 6-4, Benson Spring 2014
CLEM-BENSON-S14S6G4
3 Leden
7 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 17
Altijd: 702
