Ga door naar hoofdinhoud
Motorola Talkabout FV700R Button Contact cleaning
Wat je nodig hebt
  1. Motorola Talkabout FV700R Button Contact cleaning, Battery: stap 1, afbeelding 1 van 1
    • Remove the back battery cover by pressing the tab to the left, and lifting.
    • A small screwdriver can aid this process.
  2. Motorola Talkabout FV700R Button Contact cleaning: stap 2, afbeelding 1 van 1
    • Remove the batteries currently in the radio.
    • When you're ready to add new batteries, place Ni-MH or AAA replacement batteries in the specified slots.
    • The orientation of the batteries is specified in the battery compartment.
  3. Motorola Talkabout FV700R Button Contact cleaning, Volume Knob: stap 3, afbeelding 1 van 1
    • Turn the Volume knob to the off position.
  4. Motorola Talkabout FV700R Button Contact cleaning: stap 4, afbeelding 1 van 2 Motorola Talkabout FV700R Button Contact cleaning: stap 4, afbeelding 2 van 2
    • Firmly grasp and pull back on the volume knob. The knob should come off smoothly.
    • This may require some twisting and force.
  5. Motorola Talkabout FV700R Button Contact cleaning, Front Faceplate: stap 5, afbeelding 1 van 1
    • Remove the four 3 millimeter T6 Torx screws from the front of the radio.
  6. Motorola Talkabout FV700R Button Contact cleaning: stap 6, afbeelding 1 van 2 Motorola Talkabout FV700R Button Contact cleaning: stap 6, afbeelding 2 van 2
    • Remove the four 3 millimeter T8 Torx screws from the back of the radio.
  7. Motorola Talkabout FV700R Button Contact cleaning: stap 7, afbeelding 1 van 3 Motorola Talkabout FV700R Button Contact cleaning: stap 7, afbeelding 2 van 3 Motorola Talkabout FV700R Button Contact cleaning: stap 7, afbeelding 3 van 3
    • Gently open the backplate of the radio. Use a flathead screwdriver to slowly pry apart the two sides.
    • Be careful, as the antenna is still attached. Pulling the two sides apart too quickly could break the antenna.
  8. Motorola Talkabout FV700R Button Contact cleaning: stap 8, afbeelding 1 van 2 Motorola Talkabout FV700R Button Contact cleaning: stap 8, afbeelding 2 van 2
    • Gently pull the circuit board away from the front faceplate.
    • Be careful not to tug the wire connecting the circuit board to the speaker, as it is still attached to the faceplate.
    • Do not touch the the button contacts on the circuit board (the button contacts are shown in the red box of the second picture). This can cause long-term damage to the radio unless you properly clean them (see Repairing Motorola TALKABOUT FV700 Two Way Radio Button Contacts Guide).
  9. Motorola Talkabout FV700R Button Contact cleaning, Motorola Talkabout FV700R Button Contact cleaning: stap 9, afbeelding 1 van 1
    • The button contacts can be seen in the red box of the picture.
  10. Motorola Talkabout FV700R Button Contact cleaning: stap 10, afbeelding 1 van 1
    • Dip q-tip in rubbing isopropyl alcohol, and swab button contacts to clean.
    • Note: Rubbing alcohol will evaporate, and does not need to be wiped off of contacts.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Kayla Brennan
737 Reputatie
6 handleidingen geschreven
Clemson, Team 6-4, Benson Spring 2014 Lid van Clemson, Team 6-4, Benson Spring 2014
CLEM-BENSON-S14S6G4
3 Leden
7 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 11
Altijd: 2,235
