Ga door naar hoofdinhoud
Motorola RAZR2 v9m Camera Replacement
Wat je nodig hebt
  1. Motorola RAZR2 v9m Camera Replacement, Battery: stap 1, afbeelding 1 van 2 Motorola RAZR2 v9m Camera Replacement, Battery: stap 1, afbeelding 2 van 2
    • Push the rear cover toward the hinge of the RAZR2. The panel will slide about 3 mm.
    Vraag FixBot
    Voeg opmerking toe
  2. Motorola RAZR2 v9m Camera Replacement: stap 2, afbeelding 1 van 3 Motorola RAZR2 v9m Camera Replacement: stap 2, afbeelding 2 van 3 Motorola RAZR2 v9m Camera Replacement: stap 2, afbeelding 3 van 3
    • Pinch the top and bottom edges of the panel and pull it away from the RAZR2.
    • The rear panel uses four small hooks to hold it in place. If the panel will not easily pull away, slide the panel more toward the hinge.
    Vraag FixBot
    Voeg opmerking toe
  3. Motorola RAZR2 v9m Camera Replacement: stap 3, afbeelding 1 van 2 Motorola RAZR2 v9m Camera Replacement: stap 3, afbeelding 2 van 2
    • Gently pull the white plastic tab to lift the battery away from the RAZR2.
    • The white plastic tab is attached to the phone. Only pull it enough to expose the edges of the battery.
    Vraag FixBot
    Voeg opmerking toe
  4. Motorola RAZR2 v9m Camera Replacement: stap 4, afbeelding 1 van 2 Motorola RAZR2 v9m Camera Replacement: stap 4, afbeelding 2 van 2
    • To remove the battery, grasp its edges pull away from the phone.
    • When installing a new battery, be sure the metal contacts on the phone line up with the ones on the battery.
    Vraag FixBot
    Voeg opmerking toe
  5. Motorola RAZR2 v9m Camera Replacement, Camera: stap 5, afbeelding 1 van 3 Motorola RAZR2 v9m Camera Replacement, Camera: stap 5, afbeelding 2 van 3 Motorola RAZR2 v9m Camera Replacement, Camera: stap 5, afbeelding 3 van 3
    • Flip open the RAZR2 with the keypad and main LCD facing you.
    • Insert a spudger into the small gap above the plastic screen.
    • Gently pry the screen away from the phone.
    Vraag FixBot
    Voeg opmerking toe
  6. Motorola RAZR2 v9m Camera Replacement: stap 6, afbeelding 1 van 3 Motorola RAZR2 v9m Camera Replacement: stap 6, afbeelding 2 van 3 Motorola RAZR2 v9m Camera Replacement: stap 6, afbeelding 3 van 3
    • The plastic screen is held in place by adhesive. Run the spudger along both sides of the screen to separate it from the RAZR2.
    • Lift the screen away from the phone.
    Vraag FixBot
    Voeg opmerking toe
  7. Motorola RAZR2 v9m Camera Replacement: stap 7, afbeelding 1 van 2 Motorola RAZR2 v9m Camera Replacement: stap 7, afbeelding 2 van 2
    • Remove the four 2-mm T5 Torx screws
    Vraag FixBot
    Voeg opmerking toe
  8. Motorola RAZR2 v9m Camera Replacement: stap 8, afbeelding 1 van 2 Motorola RAZR2 v9m Camera Replacement: stap 8, afbeelding 2 van 2
    • Use a plastic opening tool to pry the top end of the metal frame away from the RAZR2.
    Vraag FixBot
    Voeg opmerking toe
  9. Motorola RAZR2 v9m Camera Replacement: stap 9, afbeelding 1 van 3 Motorola RAZR2 v9m Camera Replacement: stap 9, afbeelding 2 van 3 Motorola RAZR2 v9m Camera Replacement: stap 9, afbeelding 3 van 3
    • Insert a plastic opening tool under the metal frame at the hinge of the RAZR2.
    • Gently pry the hinge portion of the metal frame away from the phone.
    • The metal frame is latched to the phone on the corner closest to the clear and end call buttons. Pry this part of the frame away last.
    Vraag FixBot
    Voeg opmerking toe
  10. Motorola RAZR2 v9m Camera Replacement: stap 10, afbeelding 1 van 3 Motorola RAZR2 v9m Camera Replacement: stap 10, afbeelding 2 van 3 Motorola RAZR2 v9m Camera Replacement: stap 10, afbeelding 3 van 3
    • Lift the frame away from the phone.
    • When reassembling, insert the latch on the metal frame into the phone before inserting any other part of the frame.
    Vraag FixBot
    Voeg opmerking toe
  11. Motorola RAZR2 v9m Camera Replacement: stap 11, afbeelding 1 van 3 Motorola RAZR2 v9m Camera Replacement: stap 11, afbeelding 2 van 3 Motorola RAZR2 v9m Camera Replacement: stap 11, afbeelding 3 van 3
    • Use the plastic opening tool to gently pry the motherboard cable out of its socket.
    Vraag FixBot
    Voeg opmerking toe
  12. Motorola RAZR2 v9m Camera Replacement: stap 12, afbeelding 1 van 3 Motorola RAZR2 v9m Camera Replacement: stap 12, afbeelding 2 van 3 Motorola RAZR2 v9m Camera Replacement: stap 12, afbeelding 3 van 3
    • Use the plastic opening tool to gently pry the LCD cable out of its socket.
    Vraag FixBot
    Voeg opmerking toe
  13. Motorola RAZR2 v9m Camera Replacement: stap 13, afbeelding 1 van 3 Motorola RAZR2 v9m Camera Replacement: stap 13, afbeelding 2 van 3 Motorola RAZR2 v9m Camera Replacement: stap 13, afbeelding 3 van 3
    • Use the plastic opening tool to gently pry the camera cable out of its socket.
    Vraag FixBot
    Voeg opmerking toe
  14. Motorola RAZR2 v9m Camera Replacement: stap 14, afbeelding 1 van 3 Motorola RAZR2 v9m Camera Replacement: stap 14, afbeelding 2 van 3 Motorola RAZR2 v9m Camera Replacement: stap 14, afbeelding 3 van 3
    • Use a plastic opening tool to gently pry the camera assembly away from the RAZR2.
    Vraag FixBot
    Voeg opmerking toe
Conclusie
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 16
Altijd: 1,343
