Inleiding
Use this guide to replace the antenna assembly found at the bottom end of your Motorola Moto X.
Wat je nodig hebt
Insert the SIM card eject tool into the hole in the side of the SIM card tray and push to eject the tray.
Remove the SIM card tray.
Insert a plastic opening tool into the seam between the front and rear covers near the SIM card slot.
Slide the plastic opening tool along the seam toward the upper corner.
Heat an iOpener and lay it over the phone for approximately 90 seconds to loosen the adhesive securing the back cover.
Remove the four 3 mm T3 Torx screws securing the lower antenna assembly to the phone.
9 andere personen hebben deze handleiding voltooid.
2 opmerkingen
Where is the wifi antenna?
I considered repairing this after ripping the connector in the battery replacement procedure. I probably will not miss it, don't have the part either
