Deze versie kan foutieve bewerkingen bevatten. Schakel over naar de recentste gecontroleerde momentopname.
Wat je nodig hebt
Deze stap is niet vertaald. Help het te vertalen
Insert an opening tool pick under the screen, starting at the top of the phone.
Slide the pick around the entire perimeter of the display to break the adhesive.
Once enough adhesive has been removed, you should be able to separate the screen by gently lifting it from the left side of the phone.
Remove the three 2.7 mm screws that surround the base of the display cable using the Torx T5 screwdriver.
Gently remove the metal piece that covers the base of the display cable.
Use the pointed end of the spudger to lift the metal casing where circled.
Underneath this metal piece is the base of the cable. Use a spudger to vertically lift the connection out of its port.
Use the Torx T5 screwdriver to remove the three 3.0 mm screws.
Use the spudger to lift up the right side of the speaker and remove the speaker from the device.
