Inleiding
For the official, updated iFixit guide, click here. This guide is archived for historical purposes.
This relatively moderate guide will walk you through with replacing the motherboard of your device. Sit tight as you'll be spending some time unscrewing a lot of screws and disconnecting connectors.
Wat je nodig hebt
Insert the spudger into the notch on the corner of the phone and lift up to remove the back case.
Use the T4 Torx Screwdriver to remove the 2 3.2 mm screws circled in the image.
10 andere personen hebben deze handleiding voltooid.
2 opmerkingen
guide states that there are 17 screws to remove (step 2) but there are 20 screws circled… Counting is hard I guess?
From step 9 it’s another phone. I’m guessing E4 (regular) but they are not the same. The vibration motor, second sim tray, and many other components disappear suddenly. Mixing different phones is very irresponsable and lazy.
