Inleiding
Use this guide to replace the charging board in your Motorola Moto E4 (XT1762).
Before you begin, download the Rescue and Smart Assistant app to backup your device and diagnose whether your problem is software or hardware related.
Wat je nodig hebt
Insert a fingernail, or spudger, into the notch on the bottom right corner to start separating the phone unit from the back cover.
Move to the bottom left corner to pry the phone out of the back cover.
Use a fingernail or spudger to pry at the notch at the bottom end of the battery.
Lever the battery out of its recess and remove it.
Use a pair of tweezers to pry up and disconnect the antenna cable.
Before reassembly check your new part for any components that might need to be transferred from the old one (e.g. microphone rubber gasket).
3 andere personen hebben deze handleiding voltooid.
