Ga door naar hoofdinhoud
Motorola Moto E Display Assembly Replacement
Wat je nodig hebt
    1. Motorola Moto E Display Assembly Replacement, Motherboard: stap 1, afbeelding 1 van 1
      • Turn off the device before beginning.
      • To remove the back cover, start at one corner and stick the plastic opening tool under the cover and pry it away from the phone.
      • With the plastic opening tool, pry all the way around the phone while lifting up on the cover.
      • You should hear a snapping sound at each corner.
      Vraag FixBot
      Voeg opmerking toe
    2. Motorola Moto E Display Assembly Replacement: stap 2, afbeelding 1 van 1
      • Unscrew the 14 4mm screws using a T4 Torx screwdriver.
      Vraag FixBot
      Voeg opmerking toe
    3. Motorola Moto E Display Assembly Replacement: stap 3, afbeelding 1 van 1
      • Using a plastic opening tool, pry up on the edges of the plastic back cover.
      • Be sure that all of the screws are out before lifting the cover. The plastic backing is fragile, and it may break.
      Vraag FixBot
      Voeg opmerking toe
    4. Motorola Moto E Display Assembly Replacement: stap 4, afbeelding 1 van 1
      • Gently lift the back plate away, exposing the motherboard. The battery will be stuck to the back of the cover, so be careful when lifting it off.
      • Do not touch the connections to the battery in the red square on the picture.
      Vraag FixBot
      Voeg opmerking toe
    5. Motorola Moto E Display Assembly Replacement: stap 5, afbeelding 1 van 1
      • Gently pull up on the red and black power cable to lift the connector out of the motherboard.
      • Move the battery and cover away from the motherboard.
      Vraag FixBot
      Voeg opmerking toe
    6. Motorola Moto E Display Assembly Replacement: stap 6, afbeelding 1 van 1
      • Remove the three 1 mm screws using a T4 Torx screwdriver.
      Vraag FixBot
      Voeg opmerking toe
    7. Motorola Moto E Display Assembly Replacement: stap 7, afbeelding 1 van 1
      • Lift up on the white plastic mount.
      • Pull the orange ribbon cable out gently.
      Vraag FixBot
      Voeg opmerking toe
    8. Motorola Moto E Display Assembly Replacement: stap 8, afbeelding 1 van 2 Motorola Moto E Display Assembly Replacement: stap 8, afbeelding 2 van 2
      • Gently pull the black ribbon cable out.
      Vraag FixBot
      Voeg opmerking toe
    9. Motorola Moto E Display Assembly Replacement: stap 9, afbeelding 1 van 1
      • Using the metal spudger, pry the motherboard away from the screen assembly.
      Vraag FixBot
      Voeg opmerking toe
    1. Motorola Moto E Display Assembly Replacement, Display Assembly: stap 10, afbeelding 1 van 1
      • Use a heat gun or hairdryer to heat up the edges. This will loosen the glue so the screen can be removed.
      • The phone will be extremely hot. Avoid direct contact with metal pieces.
      Vraag FixBot
      Voeg opmerking toe
    2. Motorola Moto E Display Assembly Replacement: stap 11, afbeelding 1 van 1
      • Gently slide the metal spudger underneath the screen and pry it away from the backing.
      • Move the metal spudger under the digitizer and along the entire length of the phone to separate the screen from the adhesive.
      • If the screen was broken, glass shards may come off of the screen and puncture skin.
      Vraag FixBot
      Voeg opmerking toe
    3. Motorola Moto E Display Assembly Replacement: stap 12, afbeelding 1 van 1
      • Continue to heat and separate until the screen comes completely apart from the rest of the phone.
      Vraag FixBot
      Voeg opmerking toe
    4. Motorola Moto E Display Assembly Replacement: stap 13, afbeelding 1 van 1
      • To put the new screen on, press the new screen and digitizer into place, and then reapply heat to adhere the new screen.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
24 andere personen hebben deze handleiding voltooid.
Alex Craig
2.611 Reputatie
5 handleidingen geschreven
Colorado Springs, Team 5-7, Panko Spring 2015 Lid van Colorado Springs, Team 5-7, Panko Spring 2015
UCCS-PANKO-S15S5G7
2 Leden
40 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 13
Afgelopen 30 dagen: 50
Altijd: 32,135
