Inleiding
In this guide you will be taught how to take apart the plastic shell of your parent unit and remove the speaker. Some soldering will be required to fully replace the speaker.
Wat je nodig hebt
Using the Phillips #1 screwdriver, remove the battery cover screw.
Remove the battery cover from its hinges and set aside.
Using the Phillips #1 screwdriver, remove the 7mm screw under the battery cover.
Using the blue plastic opening tools, begin prying open the corners and disconnecting the seven clasps around the edges of the parent unit.
