Ga door naar hoofdinhoud
Motorola Droid Rear Case Replacement
Wat je nodig hebt
  1. Motorola Droid Rear Case Replacement, Battery: stap 1, afbeelding 1 van 3 Motorola Droid Rear Case Replacement, Battery: stap 1, afbeelding 2 van 3 Motorola Droid Rear Case Replacement, Battery: stap 1, afbeelding 3 van 3
    • Slide the battery cover downwards while applying pressure to the center of the battery cover with your thumb.
    • Lift and remove the battery cover out from the phone.
    Vraag FixBot
    Voeg opmerking toe
  2. Motorola Droid Rear Case Replacement: stap 2, afbeelding 1 van 1
    • Grasp the upper left corner of the battery and lift it out of its housing.
    Vraag FixBot
    Voeg opmerking toe
  3. Motorola Droid Rear Case Replacement, Rear Case: stap 3, afbeelding 1 van 1
    • Use a spudger to lift and remove the black plastic screw cover at the top of the phone near the camera.
    • The cover is attached by adhesive, so some force may be required.
    Vraag FixBot
    Voeg opmerking toe
  4. Motorola Droid Rear Case Replacement: stap 4, afbeelding 1 van 2 Motorola Droid Rear Case Replacement: stap 4, afbeelding 2 van 2
    • Using the tip of a spudger, peel up one corner of the gold ribbon beneath the battery compartment.
    • Peel the ribbon up off the phone.
    Vraag FixBot
    Voeg opmerking toe
  5. Motorola Droid Rear Case Replacement: stap 5, afbeelding 1 van 2 Motorola Droid Rear Case Replacement: stap 5, afbeelding 2 van 2
    • Carefully peel the device information label that covers the motherboard EMI shields.
    • This label contains important information specific to the phone. Remove it with care and keep it in a safe place.
    Vraag FixBot
    Voeg opmerking toe
  6. Motorola Droid Rear Case Replacement: stap 6, afbeelding 1 van 1
    • Insert the flat end of a spudger and pry the plastic camera cover up off the phone.
    • The thin plastic cover is attached to the phone with an adhesive. Work slowly and carefully.
    Vraag FixBot
    Voeg opmerking toe
  7. Motorola Droid Rear Case Replacement: stap 7, afbeelding 1 van 1
    • Remove the seven 5.5 mm T5 Torx screws securing the rear case to the inner case.
    Vraag FixBot
    Voeg opmerking toe
  8. Motorola Droid Rear Case Replacement: stap 8, afbeelding 1 van 1
    • Insert the flat end of a spudger and pry downwards to release the plastic tab holding the rear case to the motherboard screw.
    Vraag FixBot
    Voeg opmerking toe
  9. Motorola Droid Rear Case Replacement: stap 9, afbeelding 1 van 1
    • Gently insert a spudger between the rear case and front case at the top of the phone, near the audio jack.
    • Carefully pry the top edge of the rear case up from the rest of the phone.
    Vraag FixBot
    Voeg opmerking toe
  10. Motorola Droid Rear Case Replacement: stap 10, afbeelding 1 van 2 Motorola Droid Rear Case Replacement: stap 10, afbeelding 2 van 2
    • With the spudger still inserted between the rear case and front case, slide the spudger along the right edge of the device, moving toward the bottom, prying as you go.
    • Continue prying along the bottom edge of the device from right to left, freeing it from the front panel.
    Vraag FixBot
    Voeg opmerking toe
  11. Motorola Droid Rear Case Replacement: stap 11, afbeelding 1 van 2 Motorola Droid Rear Case Replacement: stap 11, afbeelding 2 van 2
    • Continue prying the rear case from the front case along the left side, moving from bottom to top.
    • Lift the rear case up out of the phone.
    Vraag FixBot
    Voeg opmerking toe
Conclusie
6 andere personen hebben deze handleiding voltooid.
Brett Hartt
132.258 Reputatie
144 handleidingen geschreven
iFixit Lid van iFixit
Staff
123 Leden
32.107 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 13
Afgelopen 30 dagen: 55
Altijd: 41,303
