Ga door naar hoofdinhoud
Motorola Droid RAZR M Display Replacement
Wat je nodig hebt
    1. Motorola Droid RAZR M Display Replacement, Front Assembly: stap 1, afbeelding 1 van 3 Motorola Droid RAZR M Display Replacement, Front Assembly: stap 1, afbeelding 2 van 3 Motorola Droid RAZR M Display Replacement, Front Assembly: stap 1, afbeelding 3 van 3
      • Open the small latch on the left side of the device by lifting gently with your finger, exposing the SIM card and microSD card slots.
      • If either of these cards are present, remove them to prevent damaging them while taking apart the phone. Our device does not have either.
      • Close the latch once the two cards are removed.
      Vraag FixBot
      Voeg opmerking toe
    2. Motorola Droid RAZR M Display Replacement: stap 2, afbeelding 1 van 3 Motorola Droid RAZR M Display Replacement: stap 2, afbeelding 2 van 3 Motorola Droid RAZR M Display Replacement: stap 2, afbeelding 3 van 3
      • Remove the six 4mm T3 Torx screws. There are 3 on each side of the device.
      Vraag FixBot
      Voeg opmerking toe
    3. Motorola Droid RAZR M Display Replacement: stap 3, afbeelding 1 van 3 Motorola Droid RAZR M Display Replacement: stap 3, afbeelding 2 van 3 Motorola Droid RAZR M Display Replacement: stap 3, afbeelding 3 van 3
      • Run the plastic opening tool under the bottom edge of the phone to detach the small plastic cover below the Verizon logo.
      • It will take some force to remove this piece. Work around the bottom corners to unlatch the two hooks holding the piece in place.
      • The small plastic hooks can break during removal. Be careful that you don't damage them, but it will take some force to get them undone.
      • Once the plastic cover is detached, pull the piece away with your fingers.
      Vraag FixBot
      Voeg opmerking toe
    4. Motorola Droid RAZR M Display Replacement: stap 4, afbeelding 1 van 2 Motorola Droid RAZR M Display Replacement: stap 4, afbeelding 2 van 2
      • Remove the three T4 Torx screws. There are three at the bottom of the device.
      Vraag FixBot
      Voeg opmerking toe
    5. Motorola Droid RAZR M Display Replacement: stap 5, afbeelding 1 van 3 Motorola Droid RAZR M Display Replacement: stap 5, afbeelding 2 van 3 Motorola Droid RAZR M Display Replacement: stap 5, afbeelding 3 van 3
      • Using the plastic opening tool, peel away the silver Motorola plate at the top of the phone. There is a fair amount of adhesive underneath, so you may have to pry it from a few different angles.
      • As soon as you can get your finger underneath, pull away the silver plate.
      Vraag FixBot
      Voeg opmerking toe
    6. Motorola Droid RAZR M Display Replacement: stap 6, afbeelding 1 van 2 Motorola Droid RAZR M Display Replacement: stap 6, afbeelding 2 van 2
      • Remove the two 7mm T4 Torx screws at the top of the device.
      Vraag FixBot
      Voeg opmerking toe
    7. Motorola Droid RAZR M Display Replacement: stap 7, afbeelding 1 van 3 Motorola Droid RAZR M Display Replacement: stap 7, afbeelding 2 van 3 Motorola Droid RAZR M Display Replacement: stap 7, afbeelding 3 van 3
      • When you detach the front from the back, don't pull the two pieces entirely apart. There is a flat orange wire that connects the two pieces that will be disconnected in the next step.
      • Snap apart the two internal clips located on the top corners of the device, and the two clips in the bottom corners.
      • Run the plastic opening tool around the edge of the entire device to pry apart the front of the phone from the back.
      • There is a small black plastic piece located at the bottom of the front assembly. Do not worry if the strip falls off; just simply snap it back on and proceed.
      Vraag FixBot
      Voeg opmerking toe
    8. Motorola Droid RAZR M Display Replacement: stap 8, afbeelding 1 van 3 Motorola Droid RAZR M Display Replacement: stap 8, afbeelding 2 van 3 Motorola Droid RAZR M Display Replacement: stap 8, afbeelding 3 van 3
      • Like a clamshell, slowly open the device from the top. Open the remainder of the device slowly while being mindful of the flat orange wire that connects the motherboard to the front assembly.
      • Undo the snap connection in the lower left corner by inserting the plastic opening tool under the end of the orange wire connected to the motherboard. Lift gently.
      • Once the snap connection is undone, pull apart the front assembly from the rest of the phone.
      Vraag FixBot
      Voeg opmerking toe
    1. Motorola Droid RAZR M Display Replacement, Display: stap 9, afbeelding 1 van 1
      • Holding the front assembly, carefully peel back the flat orange wire that is attached to the display from the silver backing. The silver backing is the plating where the speaker is located.'''
      Vraag FixBot
      Voeg opmerking toe
    2. Motorola Droid RAZR M Display Replacement: stap 10, afbeelding 1 van 1
      • Remove the speaker from the display by unhooking it from the two small metal spines on either side of the speaker marked by two the red squares.
      • In addition to the two metal spines, there is adhesive underneath the top of the silver plating of the speaker attaching it to the display.
      Vraag FixBot
      Voeg opmerking toe
    3. Motorola Droid RAZR M Display Replacement: stap 11, afbeelding 1 van 1
      • Carefully lift the silver plating out of the metal spines, separating it from the display.
      • You will then be left with display with the orange wire attached.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
7 andere personen hebben deze handleiding voltooid.
Connor HennesseyNiland
372 Reputatie
1 Handleiding geschreven
Cal Poly, Team 15-1, Amido Spring 2015 Lid van Cal Poly, Team 15-1, Amido Spring 2015
CPSU-AMIDO-S15S15G1
4 Leden
56 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 7
Afgelopen 30 dagen: 30
Altijd: 3,014
