Ga door naar hoofdinhoud
Motorola Droid Pro Motherboard Replacement
Wat je nodig hebt
    1. Motorola Droid Pro Motherboard Replacement, Battery: stap 1, afbeelding 1 van 1
      • Remove the back cover using the thumb tab located on the bottom of the phone.
      Vraag FixBot
      Voeg opmerking toe
    2. Motorola Droid Pro Motherboard Replacement: stap 2, afbeelding 1 van 2 Motorola Droid Pro Motherboard Replacement: stap 2, afbeelding 2 van 2
      • Remove the battery using the thumb tab.
      Vraag FixBot
      Voeg opmerking toe
    1. Motorola Droid Pro Motherboard Replacement, SD Card/SIM Card PCB Board: stap 3, afbeelding 1 van 2 Motorola Droid Pro Motherboard Replacement, SD Card/SIM Card PCB Board: stap 3, afbeelding 2 van 2
      • Using a T4 Torx driver, remove the eight 4 mm back panel screws.
      Vraag FixBot
      Voeg opmerking toe
    2. Motorola Droid Pro Motherboard Replacement: stap 4, afbeelding 1 van 3 Motorola Droid Pro Motherboard Replacement: stap 4, afbeelding 2 van 3 Motorola Droid Pro Motherboard Replacement: stap 4, afbeelding 3 van 3
      • Use a plastic opening tool to open the phone along the sides between the front panel and the chrome trim.
      • It is held together by small clips that lock in. You may have to use extra force to unlock them.
      • Go around on all sides of the phone, unlocking the clips. Then pull the back panel off.
      Vraag FixBot
      Voeg opmerking toe
    3. Motorola Droid Pro Motherboard Replacement: stap 5, afbeelding 1 van 2 Motorola Droid Pro Motherboard Replacement: stap 5, afbeelding 2 van 2
      • Gently lift the SD & SIM card board (PCB) as shown.
      • There is a ribbon cable attached underneath. Gently pull the PCB board away from the phone and it will detach easily.
      Vraag FixBot
      Voeg opmerking toe
    1. Motorola Droid Pro Motherboard Replacement, Motherboard: stap 6, afbeelding 1 van 2 Motorola Droid Pro Motherboard Replacement, Motherboard: stap 6, afbeelding 2 van 2
      • Use your plastic opening tool to disconnect the motherboard/keyboard ribbon cable.
      • There are small tabs on the side of the connectors to wedge your tool under.
      Vraag FixBot
      Voeg opmerking toe
    2. Motorola Droid Pro Motherboard Replacement: stap 7, afbeelding 1 van 2 Motorola Droid Pro Motherboard Replacement: stap 7, afbeelding 2 van 2
      • Use your plastic opening tool to disconnect the two ribbon cables at the top of the phone.
      Vraag FixBot
      Voeg opmerking toe
    3. Motorola Droid Pro Motherboard Replacement: stap 8, afbeelding 1 van 2 Motorola Droid Pro Motherboard Replacement: stap 8, afbeelding 2 van 2
      • Disconnect the 2nd keyboard connector from the motherboard and remove it from its side holders.
      • This cable is fragile so be careful when disconnecting and moving it around.
      Vraag FixBot
      Voeg opmerking toe
    4. Motorola Droid Pro Motherboard Replacement: stap 9, afbeelding 1 van 1
      • Use a T5 Torx Screwdriver to unscrew the 2mm screw.
      Vraag FixBot
      Voeg opmerking toe
    5. Motorola Droid Pro Motherboard Replacement: stap 10, afbeelding 1 van 3 Motorola Droid Pro Motherboard Replacement: stap 10, afbeelding 2 van 3 Motorola Droid Pro Motherboard Replacement: stap 10, afbeelding 3 van 3
      • Remove the camera's rubber seal by pulling it off. It is not connected to anything.
      Vraag FixBot
      Voeg opmerking toe
    6. Motorola Droid Pro Motherboard Replacement: stap 11, afbeelding 1 van 2 Motorola Droid Pro Motherboard Replacement: stap 11, afbeelding 2 van 2
      • To remove the motherboard, pull it to the side. The camera that is connected to the motherboard does not pull straight up and out from its holder.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
3 andere personen hebben deze handleiding voltooid.
Richard Bellizzi
352 Reputatie
2 handleidingen geschreven
UMass Dartmouth, Team 1-6, Miles Fall 2015 Lid van UMass Dartmouth, Team 1-6, Miles Fall 2015
UMASSD-MILES-F15S1G6
3 Leden
42 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 9
Afgelopen 30 dagen: 35
Altijd: 689
