Ga door naar hoofdinhoud
Motorola Defy XT Logic Board Replacement
Wat je nodig hebt
  1. Motorola Defy XT Logic Board Replacement, Logic Board: stap 1, afbeelding 1 van 1
    • Wedge the opening tool in-between the back cover and the body of the phone in the opening denoted by the arrow.
    Vraag FixBot
    Voeg opmerking toe
  2. Motorola Defy XT Logic Board Replacement: stap 2, afbeelding 1 van 1
    • Once wedged in the opening, slide the opening tool around the side of the phone and remove the back cover, setting it aside.
    Vraag FixBot
    Voeg opmerking toe
  3. Motorola Defy XT Logic Board Replacement: stap 3, afbeelding 1 van 1
    • Insert the opening tool between the battery and the battery holder and wedge the battery out.
    Vraag FixBot
    Voeg opmerking toe
  4. Motorola Defy XT Logic Board Replacement: stap 4, afbeelding 1 van 1
    • Open the plastic cover with your finger to expose the SD card.
    • Use the opening tool to grab the edge of the SD card and pull it straight out.
    Vraag FixBot
    Voeg opmerking toe
  5. Motorola Defy XT Logic Board Replacement: stap 5, afbeelding 1 van 1
    • Remove the six 6mm T4 screws with the T4 torque driver.
    Vraag FixBot
    Voeg opmerking toe
  6. Motorola Defy XT Logic Board Replacement: stap 6, afbeelding 1 van 1
    • Pop out the volume button with the plastic opening tool.
    Vraag FixBot
    Voeg opmerking toe
  7. Motorola Defy XT Logic Board Replacement: stap 7, afbeelding 1 van 2 Motorola Defy XT Logic Board Replacement: stap 7, afbeelding 2 van 2
    • Wedge the plastic opening tool in-between the plastic layer and the front cover.
    • Do not completely separate the two pieces to avoid damaging the ribbon cable inside.
    Vraag FixBot
    Voeg opmerking toe
  8. Motorola Defy XT Logic Board Replacement: stap 8, afbeelding 1 van 1
    • Carefully separate the bottom piece from the top plastic piece.
    • Disconnect the ribbon cable connecting the display to the logic board by firmly pulling the cable straight outward.
    • The screen can now be removed.
    Vraag FixBot
    Voeg opmerking toe
  9. Motorola Defy XT Logic Board Replacement: stap 9, afbeelding 1 van 1
    • Separate the logic board and the display cover from the back cover and orient the logic board so the camera faces toward you.
    • Disconnect the back cover by wedging the plastic opening tool in between the motherboard and the connector and prying outward.
    Vraag FixBot
    Voeg opmerking toe
  10. Motorola Defy XT Logic Board Replacement: stap 10, afbeelding 1 van 1
    • Flip the logic board and display cover over so the camera faces away from you.
    • Bend the two halves of the device away from you to pry the final ribbon connector off the logic board.
    • The ribbon connector is bonded to the logic board with adhesive, simply pull it to break the glue bond.
    Vraag FixBot
    Voeg opmerking toe
Conclusie
No Name
25 Reputatie
1 Handleiding geschreven
2Gids Commentaar
Imbecells give up DEMONIC HOLD PRAISE THE LORD HE HAS COME 4 U
True Seminary - Antwoord Deel
idoits have faith like a lil ole mustard seed
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 32
Altijd: 1,705
