Inleiding
Motorola Cliq (or Motorola Dext) smartphones use LCD (Liquid Crystal Display) screens, which are popular for their high-contrast visuals and touch sensitivity. However, LCD screens can become damaged or broken, either due to physical trauma or gradually over time. Symptoms of a broken LCD screen include rainbow patterns, black spots that do not change with new images or video frames, flickering images, or total black screens; becoming unresponsive is also a common effect of damaged LCD screens.
Before starting repairs, ensure that the damage to your screen is indeed the LCD screen, not simply the tempered glass or phone screen. If your screen is cracked but still responsive to your touch and not discolored, then an LCD screen replacement is unnecessary.
This tutorial is meant to guide you through the process of replacing your Motorola Cliq LCD screen. LCD screen replacement requires opening the device and working from within its contents. It’s important that you do not fully separate certain parts, such as in Steps 5 and 13. Step 9 involves gently prying a glued-down ZIF connector down without ripping it off altogether. Failure to treat these parts with the appropriate care will lead to an outright unusable device. As such, please proceed with patience and gentle movements as you remove and replace the damaged LCD screen.
Always power off your smartphone beforehand to reduce the risk of batteries short-circuiting and electrocuting you during repair.
Wat je nodig hebt
Turning over your phone, place two fingers on the back cover and apply pressure away from the camera to slide the back cover off.
Wedge a plastic opening tool behind the panel covering the camera, pry it up, and remove it using your fingers.
Turn the phone over and slide out the keyboard.
Wedge a plastic opening tool where the keyboard meets the back casing of the phone next to the headphone jack.
Carefully pry open the back casing along the keyboard's edge until at least two corners of the back casing are separated from the keyboard.
Wedge the plastic opening tool underneath the black display connector and pry it off its socket on the motherboard.
Pry off the flex cable located at the top right of the display assembly using the flat end of a spudger.
3 andere personen hebben deze handleiding voltooid.
