Ga door naar hoofdinhoud
Motorola Cliq Camera Replacement
Wat je nodig hebt
  1. Motorola Cliq Camera Replacement, Battery: stap 1, afbeelding 1 van 2 Motorola Cliq Camera Replacement, Battery: stap 1, afbeelding 2 van 2
    • Turning over your phone, place two fingers on the back cover and apply pressure away from the camera to slide the back cover off.
    Vraag FixBot
    Voeg opmerking toe
  2. Motorola Cliq Camera Replacement: stap 2, afbeelding 1 van 2 Motorola Cliq Camera Replacement: stap 2, afbeelding 2 van 2
    • Pinch the battery pull tab located below the camera, pull it upwards, and remove the battery.
    • The pull tab may be tucked under the battery.
    Vraag FixBot
    Voeg opmerking toe
  3. Motorola Cliq Camera Replacement, Rear Casing: stap 3, afbeelding 1 van 3 Motorola Cliq Camera Replacement, Rear Casing: stap 3, afbeelding 2 van 3 Motorola Cliq Camera Replacement, Rear Casing: stap 3, afbeelding 3 van 3
    • Wedge a plastic opening tool behind the panel covering the camera, pry it up, and remove it using your fingers.
    • The panel is held down by adhesive and may require you to wedge and pry the right side of the panel before it can be easily removed.
    Vraag FixBot
    Voeg opmerking toe
  4. Motorola Cliq Camera Replacement: stap 4, afbeelding 1 van 1
    • Remove the six 4.0 mm T4 Torx screws which line the edge of the back of the phone.
    Vraag FixBot
    Voeg opmerking toe
  5. Motorola Cliq Camera Replacement: stap 5, afbeelding 1 van 3 Motorola Cliq Camera Replacement: stap 5, afbeelding 2 van 3 Motorola Cliq Camera Replacement: stap 5, afbeelding 3 van 3
    • Turn the phone over and slide out the keyboard.
    • Wedge a plastic opening tool where the keyboard meets the back casing of the phone next to the headphone jack.
    • Carefully pry open the back casing along the keyboard's edge until at least two corners of the back casing are separated from the keyboard.
    • Do not fully separate the rear panel from the phone. A cable is connecting the two parts together.
    Vraag FixBot
    Voeg opmerking toe
  6. Motorola Cliq Camera Replacement: stap 6, afbeelding 1 van 1
    • Carefully separate the back casing from the rest of the phone.
    Vraag FixBot
    Voeg opmerking toe
  7. Motorola Cliq Camera Replacement: stap 7, afbeelding 1 van 2 Motorola Cliq Camera Replacement: stap 7, afbeelding 2 van 2
    • Gently pry ZIF connector upwards using the flat end of a spudger tool.
    • The ZIF connector is glued down. Be gentle! Ripping it off or breaking it will make your phone inoperable.
    • You may need adhesive to keep your power cable in place when reassembling your phone.
    Vraag FixBot
    Voeg opmerking toe
  8. Motorola Cliq Camera Replacement: stap 8, afbeelding 1 van 3 Motorola Cliq Camera Replacement: stap 8, afbeelding 2 van 3 Motorola Cliq Camera Replacement: stap 8, afbeelding 3 van 3
    • Press your thumb against the orange power cable and pull it down slowly to disconnect the power cable from the bottom of the keyboard.
    • The rear casing and the rest of the phone should now be completely separated.
    Vraag FixBot
    Voeg opmerking toe
  9. Motorola Cliq Camera Replacement, Camera: stap 9, afbeelding 1 van 3 Motorola Cliq Camera Replacement, Camera: stap 9, afbeelding 2 van 3 Motorola Cliq Camera Replacement, Camera: stap 9, afbeelding 3 van 3
    • Insert a 1.5mm flat head screw in the slit in between the camera housing and the bottom of the camera.
    • Lightly pry upwards and the camera should come loose from the housing.
    Vraag FixBot
    Voeg opmerking toe
  10. Motorola Cliq Camera Replacement: stap 10, afbeelding 1 van 3 Motorola Cliq Camera Replacement: stap 10, afbeelding 2 van 3 Motorola Cliq Camera Replacement: stap 10, afbeelding 3 van 3
    • Carefully grab the sides of the camera with your fingers and remove the camera.
    • The foam cover on the top of the camera deforms and tears easily, so handle it with care.
    Vraag FixBot
    Voeg opmerking toe
Conclusie
Tony Tran
84 Reputatie
8 handleidingen geschreven
Cal Poly, Team 10-42, Amido Spring 2013 Lid van Cal Poly, Team 10-42, Amido Spring 2013
CPSU-AMIDO-S13S10G42
4 Leden
32 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 9
Afgelopen 30 dagen: 44
Altijd: 727
