Ga door naar hoofdinhoud
Motorola C261 Front Housing Replacement
Wat je nodig hebt
    1. Motorola C261 Front Housing Replacement, Place Phone: stap 1, afbeelding 1 van 1
      • Place the phone with the screen facedown on a flat surface.
      Vraag FixBot
      Voeg opmerking toe
    2. Motorola C261 Front Housing Replacement, Latch and Back Cover: stap 2, afbeelding 1 van 2 Motorola C261 Front Housing Replacement, Latch and Back Cover: stap 2, afbeelding 2 van 2
      • Pinch the latch upwards towards the top of the phone.
      • Lift the back cover of the phone.
      • There are tabs on the bottom end of the battery cover that the cover pivots about.
      Vraag FixBot
      Voeg opmerking toe
    3. Motorola C261 Front Housing Replacement, Remove Battery: stap 3, afbeelding 1 van 2 Motorola C261 Front Housing Replacement, Remove Battery: stap 3, afbeelding 2 van 2
      • Remove the battery by pressing on the edge of the battery from the top of the phone towards the bottom and lifting up.
      Vraag FixBot
      Voeg opmerking toe
    1. Motorola C261 Front Housing Replacement, Screws in Rear Housing: stap 4, afbeelding 1 van 1
      • Remove the four 8.5 mm screws from under the battery cover with a T4 Torx screwdriver.
      • Remove the two 8.5 mm screws from the top of the phone with a T4 Torx screwdriver.
      Vraag FixBot
      Voeg opmerking toe
    2. Motorola C261 Front Housing Replacement, Rear Housing: stap 5, afbeelding 1 van 2 Motorola C261 Front Housing Replacement, Rear Housing: stap 5, afbeelding 2 van 2
      • Using the plastic pry tool remove the rear housing from the rest of the phone. You may have to pry around all edges of the phone, not just the edge shown.
      • When you remove the rear housing, the rubber cover for the headphone jack/charge port may fall out. If not, remove it.
      Vraag FixBot
      Voeg opmerking toe
    3. Motorola C261 Front Housing Replacement, Spacers: stap 6, afbeelding 1 van 2 Motorola C261 Front Housing Replacement, Spacers: stap 6, afbeelding 2 van 2
      • Remove the small black circular rubber spacer.
      • Remove the white rubber spacer.
      • These pieces are small and easy to lose, especially the black one. Set them somewhere safe!
      Vraag FixBot
      Voeg opmerking toe
    4. Motorola C261 Front Housing Replacement, Motherboard and Front Housing: stap 7, afbeelding 1 van 2 Motorola C261 Front Housing Replacement, Motherboard and Front Housing: stap 7, afbeelding 2 van 2
      • Gently remove the motherboard assembly from the front housing.
      • Now, the front housing is free to be replaced, as well as the cosmetic keypad.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
Helen Karsten
209 Reputatie
2 handleidingen geschreven
Michigan Tech, Team 1-6, Lauer Fall 2014 Lid van Michigan Tech, Team 1-6, Lauer Fall 2014
MTU-LAUER-F14S1G6
3 Leden
35 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 6
Afgelopen 30 dagen: 30
Altijd: 415
