Ga door naar hoofdinhoud
Motorola Atrix HD Rear Chassis Disassembly
Wat je nodig hebt
  1. Motorola Atrix HD Rear Chassis Disassembly, Rear Chassis: stap 1, afbeelding 1 van 3 Motorola Atrix HD Rear Chassis Disassembly, Rear Chassis: stap 1, afbeelding 2 van 3 Motorola Atrix HD Rear Chassis Disassembly, Rear Chassis: stap 1, afbeelding 3 van 3
    • Begin by removing the back cover using the plastic opening tool. There are adhesive strips attached to the back cover, so take care when prying case to prevent cracking
    • The adhesive strips may stay on the back cover or the battery.
    Vraag FixBot
    Voeg opmerking toe
  2. Motorola Atrix HD Rear Chassis Disassembly: stap 2, afbeelding 1 van 2 Motorola Atrix HD Rear Chassis Disassembly: stap 2, afbeelding 2 van 2
    • The back case portion may be removed after the battery has been removed.
    • Use the T5 Torx screwdriver to remove the 10 coarse-thread 5mm screws
    Vraag FixBot
    Voeg opmerking toe
  3. Motorola Atrix HD Rear Chassis Disassembly: stap 3, afbeelding 1 van 3 Motorola Atrix HD Rear Chassis Disassembly: stap 3, afbeelding 2 van 3 Motorola Atrix HD Rear Chassis Disassembly: stap 3, afbeelding 3 van 3
    • Now with the screws removed, use the plastic opening tool to lift the edges of the front assembly.
    • Continue to use the plastic opening tool around the edges of the device to remove the front assembly.
    • The speaker is located in the upper corner of the case. It it attached with adhesive and can be removed by gently prying with the plastic opening tool
    Vraag FixBot
    Voeg opmerking toe
Conclusie
Gabriel Agaman
597 Reputatie
3 handleidingen geschreven
UMass Dartmouth, Team 1-8, Miles Fall 2015 Lid van UMass Dartmouth, Team 1-8, Miles Fall 2015
UMASSD-MILES-F15S1G8
3 Leden
15 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 9
Afgelopen 30 dagen: 22
Altijd: 573
