Ga door naar hoofdinhoud
Motor Replacement
Wat je nodig hebt
    1. Motor Replacement, Motor: stap 1, afbeelding 1 van 2 Motor Replacement, Motor: stap 1, afbeelding 2 van 2
      • Use a phillips head screwdriver to unscrew the following 8 screws:
      • One 24mm Phillips screw
      • Six 16mm Phillips screws
      • One 9mm Phillips screw
      • Turn the drill to the other side and unscrew the marked screw using the same phillips head screwdriver. Place it with the other removed screws.
      • Keep all screws organized on a magnetic mat after removal.
      Vraag FixBot
      Voeg opmerking toe
    2. Motor Replacement: stap 2, afbeelding 1 van 2 Motor Replacement: stap 2, afbeelding 2 van 2
      • Carefully remove the plastic drill casing by pulling it apart.
      Vraag FixBot
      Voeg opmerking toe
    3. Motor Replacement: stap 3, afbeelding 1 van 2 Motor Replacement: stap 3, afbeelding 2 van 2
      • Identify and remove the drill hardware from the plastic casing.
      • Locate the motor.
      Vraag FixBot
      Voeg opmerking toe
    4. Motor Replacement: stap 4, afbeelding 1 van 3 Motor Replacement: stap 4, afbeelding 2 van 3 Motor Replacement: stap 4, afbeelding 3 van 3
      • Using a phillips head screwdriver, unscrew the four black (9mm) screws located on the plastic attachment at the bottom of the motor.
      • Carefully remove the motor and the plastic attachment from the rest of the drill hardware.
      • Be sure to handle the chuck and remaining drill hardware carefully as gears may fall out of place. Do not turn upside down.
      Vraag FixBot
      Voeg opmerking toe
    5. Motor Replacement: stap 5, afbeelding 1 van 3 Motor Replacement: stap 5, afbeelding 2 van 3 Motor Replacement: stap 5, afbeelding 3 van 3
      Gereedschap gebruikt in deze stap:
      • Unscrew the plastic attachment from the motor using a phillips head screwdriver. Keep the screws (7mm) after removal.
      • After the screws are removed, detach the plastic attachment from the motor and set aside.
      • Finally, detach the wires from the motor to completely isolate the motor. The wires should wiggle off easily using ESD safe tweezers. It is now successfully removed from the drill and is ready to be replaced.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
1Gids Commentaar
Any chance you could upload a picture of the motor text without the box going through it, or add the info somewhere? I burnt out the switch and/or transistor in my ss12, so I decided to salvage the motor but the markings on my motor are different even though it looks identical and came from the same drill. I want to use it to build a radial fan for use in an air filter. It would be a huge help in getting the specs (or at least some info) on the motor. Thank you.
Zak Grimm - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 6
Afgelopen 30 dagen: 46
Altijd: 1,992
