Inleiding
This guide disassembles the capture button, so the device can be checked for a broken spring or for debris blocking its movement.
Wat je nodig hebt
Gereedschap gebruikt in deze stap:Tweezers$4.99
Choosing the front half of the casing, locate the capture button on the top.
Using tweezers, apply pressure to the two black hooks (circled in red) while holding the button down from the outside of the case.
Reassemble the casing by reversing steps 1 and 2.
