Inleiding
This guide will walk through the steps to replace the forward/reverse shuttle on the Milwaukee M12 2407-20.
Wat je nodig hebt
Remove each of the seven 14mm Pan Hd. T-10 ST screws on one side of the housing assembly using the T10 screwdriver.
Use both hands to lift and remove the gear case assembly from the shell casing.
Set the gear case assembly aside.
4 andere personen hebben deze handleiding voltooid.
