Ga door naar hoofdinhoud
Milwaukee Hex Impact Driver 2753-20 Trigger Replacement
Wat je nodig hebt
  1. Milwaukee Hex Impact Driver 2753-20 Trigger Replacement, Battery: stap 1, afbeelding 1 van 2 Milwaukee Hex Impact Driver 2753-20 Trigger Replacement, Battery: stap 1, afbeelding 2 van 2
    • While pinching the red locking buttons, pull the battery away from the front of the drill until the battery is fully removed.
    • The battery is missing from this device so its removal is being mimed.
  2. Milwaukee Hex Impact Driver 2753-20 Trigger Replacement, Milwaukee Hex Impact Driver 2753-20 Cover Removal: stap 2, afbeelding 1 van 1
    • Using the Torx T10 screwdriver, remove the six 17 mm screws on the outside of the handle.
    • Remove the two 40 mm Torx T10 screws near the bottom of the cover.
  3. Milwaukee Hex Impact Driver 2753-20 Trigger Replacement: stap 3, afbeelding 1 van 2 Milwaukee Hex Impact Driver 2753-20 Trigger Replacement: stap 3, afbeelding 2 van 2
    • Carefully remove the cover.
    • If there is buildup from sawdust or sediment it might be a little difficult to take apart.
  4. Milwaukee Hex Impact Driver 2753-20 Trigger Replacement, Trigger: stap 4, afbeelding 1 van 2 Milwaukee Hex Impact Driver 2753-20 Trigger Replacement, Trigger: stap 4, afbeelding 2 van 2
    • Lift the trigger assembly from the device. It is connected to the circuit board by wires.
    • Carefully desolder the wires off of the trigger assembly using a soldering iron on medium heat.
    • Refer to this guide for proper desoldering technique.
  5. Milwaukee Hex Impact Driver 2753-20 Trigger Replacement: stap 5, afbeelding 1 van 1
    • Remove the trigger assembly from the device.
    • Replace old trigger assembly with replacement part no. 14-20-0013.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Alex Larson
243 Reputatie
2 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 8
Afgelopen 30 dagen: 44
Altijd: 4,528
