Ga door naar hoofdinhoud
Milwaukee Circular Saw 263020 B57A 2008 Trigger Replacement
Wat je nodig hebt
  1. Milwaukee Circular Saw 263020 B57A 2008 Trigger Replacement, Back Panel: stap 1, afbeelding 1 van 1
    • Orient your saw sideways so that the blade is facing downwards.
  2. Milwaukee Circular Saw 263020 B57A 2008 Trigger Replacement: stap 2, afbeelding 1 van 3 Milwaukee Circular Saw 263020 B57A 2008 Trigger Replacement: stap 2, afbeelding 2 van 3 Milwaukee Circular Saw 263020 B57A 2008 Trigger Replacement: stap 2, afbeelding 3 van 3
    • Remove the nine 6 mm screws using a Torx T4 screwdriver.
    • Remove the single 8 mm screw at the bottom that attaches the panels together using a Torx T6 screwdriver.
    • Slowly pull and remove the front panel of the saw that connects to the blade side with your hand, and separate it from the motor.
  3. Milwaukee Circular Saw 263020 B57A 2008 Trigger Replacement, Trigger: stap 3, afbeelding 1 van 2 Milwaukee Circular Saw 263020 B57A 2008 Trigger Replacement, Trigger: stap 3, afbeelding 2 van 2
    • Remove four 10 mm screws that attach the wires to the trigger using a Phillips #2 screwdriver.
    • Gently move the wires from the trigger (the wires should just come off).
Conclusie
Ahmed Altawami
473 Reputatie
4 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 7
Afgelopen 7 dagen: 13
Afgelopen 30 dagen: 35
Altijd: 152
