Ga door naar hoofdinhoud
Mid F900 Speaker Replacement
Wat je nodig hebt
  1. Mid F900 Speaker Replacement, Back Cover: stap 1, afbeelding 1 van 1
    • Using a J00 Phillips-head screwdriver, remove the two screws located at the bottom of the device.
    • Screws are 5mm x 1mm in size.
  2. Mid F900 Speaker Replacement: stap 2, afbeelding 1 van 2 Mid F900 Speaker Replacement: stap 2, afbeelding 2 van 2
    • Use the plastic opening tool to pry off the white back-plate of the device.
  3. Mid F900 Speaker Replacement, Speaker: stap 3, afbeelding 1 van 1
    • Follow the black and red wires coming from the white back plate to the motherboard.
    • For soldering help, use the How to Solder and Desolder Connections guide.
    • Carefully use the soldering iron to desolder the wires from the motherboard.
    • Do not keep the soldering gun on the motherboard for too long or damage may occur to the device.
  4. Mid F900 Speaker Replacement: stap 4, afbeelding 1 van 1
    • Use the nylon spudger to gently pry the speaker from the case. Then put the new speaker in.
    • You will need to resolder the wires from the new speaker to the motherboard.
Conclusie
Jacques Pierre
336 Reputatie
2 handleidingen geschreven
USF Tampa, Team 6-6, Remmell Fall 2016 Lid van USF Tampa, Team 6-6, Remmell Fall 2016
USFT-REMMELL-F16S6G6
3 Leden
10 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 7
Altijd: 150
