Ga door naar hoofdinhoud
Mid F900 Microphone Replacement
Wat je nodig hebt
  1. Mid F900 Microphone Replacement, Back Cover: stap 1, afbeelding 1 van 1
    • Using a J00 Phillips-head screwdriver, remove the two screws located at the bottom of the device.
    • Screws are 5mm x 1mm in size.
  2. Mid F900 Microphone Replacement: stap 2, afbeelding 1 van 2 Mid F900 Microphone Replacement: stap 2, afbeelding 2 van 2
    • Use the plastic opening tool to pry off the white back-plate of the device.
  3. Mid F900 Microphone Replacement, Motherboard: stap 3, afbeelding 1 van 2 Mid F900 Microphone Replacement, Motherboard: stap 3, afbeelding 2 van 2
    • Using a +00 Phillips head screwdriver, remove the screws securing the motherboard to the device housing.
    • Screws are 4mm x 1mm in size.
  4. Mid F900 Microphone Replacement: stap 4, afbeelding 1 van 2 Mid F900 Microphone Replacement: stap 4, afbeelding 2 van 2
    • Desolder the two black and red wires connected to the motherboard.
    • Unclip and remove the ribbon cables attached to the motherboard.
    • For soldering help, use the How to Solder and Desolder Connections guide.
  5. Mid F900 Microphone Replacement: stap 5, afbeelding 1 van 2 Mid F900 Microphone Replacement: stap 5, afbeelding 2 van 2
    • Carefully lift and remove the motherboard from the device housing.
  6. Mid F900 Microphone Replacement, Microphone: stap 6, afbeelding 1 van 1
    • Flip the motherboard over to bring the underside into view.
    • Find and desolder the microphone near the bottom of the motherboard and remove it.
    • Solder the new microphone in its place.
    • For soldering help, check out the How to Solder and Desolder Connections guide.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Matthew Oliva
364 Reputatie
3 handleidingen geschreven
USF Tampa, Team 6-6, Remmell Fall 2016 Lid van USF Tampa, Team 6-6, Remmell Fall 2016
USFT-REMMELL-F16S6G6
3 Leden
10 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 2
Altijd: 120
