Ga door naar hoofdinhoud
Microtek ScanMaker 5900 New Upper Lid Bulbs Replacement
Wat je nodig hebt
    1. Microtek ScanMaker 5900 New Upper Lid Bulbs Replacement, Remove serial port connection: stap 1, afbeelding 1 van 3 Microtek ScanMaker 5900 New Upper Lid Bulbs Replacement, Remove serial port connection: stap 1, afbeelding 2 van 3 Microtek ScanMaker 5900 New Upper Lid Bulbs Replacement, Remove serial port connection: stap 1, afbeelding 3 van 3
      • Loosen the screws on the serial port by turning them counter clockwise by hand.
      • After loosening the screws, pull the serial port out.
      Vraag FixBot
      Voeg opmerking toe
    2. Microtek ScanMaker 5900 New Upper Lid Bulbs Replacement, Remove Lid: stap 2, afbeelding 1 van 3 Microtek ScanMaker 5900 New Upper Lid Bulbs Replacement, Remove Lid: stap 2, afbeelding 2 van 3 Microtek ScanMaker 5900 New Upper Lid Bulbs Replacement, Remove Lid: stap 2, afbeelding 3 van 3
      • Lift lid to its vertical position.
      • Pull lid straight up to remove it from the scanner.
      Vraag FixBot
      Voeg opmerking toe
    1. Microtek ScanMaker 5900 New Upper Lid Bulbs Replacement, Remove the protective plastic covering: stap 3, afbeelding 1 van 3 Microtek ScanMaker 5900 New Upper Lid Bulbs Replacement, Remove the protective plastic covering: stap 3, afbeelding 2 van 3 Microtek ScanMaker 5900 New Upper Lid Bulbs Replacement, Remove the protective plastic covering: stap 3, afbeelding 3 van 3
      Gereedschap gebruikt in deze stap:
      • Notice that there are two plastic tabs that need to be pushed in to remove the plastic covering.
      • Use tweezers to push these tabs in.
      • Gently pull the plastic covering off of the upper lid.
      Vraag FixBot
      Voeg opmerking toe
    2. Microtek ScanMaker 5900 New Upper Lid Bulbs Replacement, Remove wires from circuit board: stap 4, afbeelding 1 van 3 Microtek ScanMaker 5900 New Upper Lid Bulbs Replacement, Remove wires from circuit board: stap 4, afbeelding 2 van 3 Microtek ScanMaker 5900 New Upper Lid Bulbs Replacement, Remove wires from circuit board: stap 4, afbeelding 3 van 3
      • Grab the plastic wire housing near the serial port.
      • Gently pull and jiggle the wire housing until it comes free from the circuit board.
      Vraag FixBot
      Voeg opmerking toe
    3. Microtek ScanMaker 5900 New Upper Lid Bulbs Replacement, Remove the bulbs: stap 5, afbeelding 1 van 2 Microtek ScanMaker 5900 New Upper Lid Bulbs Replacement, Remove the bulbs: stap 5, afbeelding 2 van 2
      • Gently lift up the bulbs and remove the wires from the plastic.
      • After completely freeing the bulbs, buy new ones and replace.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
Taylor Nesheim
59 Reputatie
7 handleidingen geschreven
Cal Poly, Team 6-9, Regan Fall 2011 Lid van Cal Poly, Team 6-9, Regan Fall 2011
CPSU-REGAN-F11S6G9
2 Leden
22 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 8
Afgelopen 30 dagen: 36
Altijd: 1,542
