Deze handleiding heeft recentere wijzigingen. Schakel over naar de nieuwste niet-geverifieerde versie.
Inleiding
This guide will go over how to replace the cameras on the Microsoft Surface Pro 5, also known as the Microsoft Surface Pro (2017). The Microsoft Surface Pro 5 has two cameras: one front facing and one rear facing. Both are located underneath the black tie bar. The iOpener is used in this guide, but a hair dryer or heat gun could also be used. See instructions for the iOpener here.
Wat je nodig hebt
Use a spudger to flip up the small locking flaps on the display cable ZIF connectors.
Slide an opening pick under the display board to separate the adhesive holding it onto the back of the screen.
Remove the ten Torx screws securing the heat sink:
Five 2.6 mm-long T3 screws
Four 3.3 mm-long T5 screws
Screw 1
Screw 2
Screw 3
Screw 4
Remove the Torx T5 x 6mm screw connecting the black tie bar to the power button/volume control/speaker assembly.
Pry off the metal cover covering the front and rear camera ribbon cable motherboard connections using a nylon spudger.
Één andere persoon heeft deze handleiding voltooid.
Één opmerking
In step 19, there is a loose, clear plastic piece next to the front camera. In my disassembly, that piece managed to get lost. Can anyone tell me what the name of that part is, and where I can get one?
