Deze versie kan foutieve bewerkingen bevatten. Schakel over naar de recentste gecontroleerde momentopname.
Wat je nodig hebt
Deze stap is niet vertaald. Help het te vertalen
Use a spudger to flip up the small locking flaps on the display cable ZIF connectors.
Gereedschap gebruikt in deze stap:Tweezers$4.99-
Use tweezers to slide the display cables straight out of their sockets on the display board.
Slide an opening pick under the display board to separate the adhesive holding it onto the back of the screen.
Gereedschap gebruikt in deze stap:Tesa 61395 Tape$5.99-
Remove the display board.
To ensure correct positioning, plug in both display connectors before adhering the board to the display.
Insert one point of a pair of pointed tweezers into a gap in the corner of the EMI shield covering the heat sink.
Use the tweezers to pry the EMI shield away from the motherboard as much as you can without bending it. Do not remove it yet.
Repeat the last step for each corner of the EMI shield covering the heat sink.
Remove the ten Torx screws securing the heat sink:
Five 2.6 mm-long T3 screws
Four 3.3 mm-long T5 screws
Screw 1
Screw 2
Screw 3
Screw 4
Use the flat end of a spudger to gently pry the heat sink straight up and off of the CPU.
Remove the Torx T5 x 6mm screw connecting the black tie bar to the power button/volume control/speaker assembly.
Remove the remaining three Torx T5 x 4.5mm screws holding down the camera tie bar.
Disconnect the small ribbon cable connecting the camera tie bar to the motherboard by pulling up with tweezers.
Pry off the metal cover covering the front and rear camera ribbon cable motherboard connections using a nylon spudger.
Lift the front camera ribbon cable off the motherboard using the nylon spudger.
Remove the two Torx T3 x 2.5mm screws holding down the rear camera.
Lift the rear camera ribbon cable off the motherboard using the nylon spudger.
Één andere persoon heeft deze handleiding voltooid.
Één opmerking
In step 19, there is a loose, clear plastic piece next to the front camera. In my disassembly, that piece managed to get lost. Can anyone tell me what the name of that part is, and where I can get one?
