Ga door naar hoofdinhoud
Microsoft Surface Pro 3 Headphone Jack Replacement
Wat je nodig hebt
  1. Microsoft Surface Pro 3 Headphone Jack Replacement, Display: stap 1, afbeelding 1 van 2 Microsoft Surface Pro 3 Headphone Jack Replacement, Display: stap 1, afbeelding 2 van 2
    • Before you begin, discharge the Surface Pro's battery below 25%. A charged lithium-ion battery can catch fire and/or explode if accidentally damaged during the repair.
    • The display is strongly glued to the frame of the device.
    • To remove the display, first soften the adhesive by applying heat. You can use a heat pad, heat gun, or iOpener. In a pinch, a hair dryer can also work.
    • Be careful when using a heat gun, as too much heat can permanently damage the display and/or battery.
    • Steadily and evenly heat the perimeter of the display until it's too hot to touch, and try to maintain that temperature for several minutes.
    I just replaced both my screen and battery. It took four hours and a couple of wrong turns but I was successful learning what to do next time. However, I am not sure I would do it again.
    It takes more heat than one imagines - all most too much and made me queasy fearing I was going to damage something. I would say it actually too hot and likely to damage something so be careful and do not prolong the removal. To get started I used a glass top warming/buffet heating tray set to about 200 degrees.  I turned the surface pro glass side down before turning it one so it would heat gradually with the tray. I let it heat for 15 minutes. In end, I am not sure it helped or not by starting this way.  This was not an easy removal so I shudder to think how worse it would have been if this didn’t help. I used a variable heat gun for the remaining steps. My screen was broken so breaking it further while nerve racking was not going to be catastrophic.
    michael jones - Antwoord
    I attempted battery replacement, but during disassembly, i damaged the display by inserting the picks to far, and separating the display circuitry from the glass.
    I used a Milwaukee precision hot tool model 1400, which has only a fixed heat setting, but it worked perfectly to soften the adhesive.
    (I was very careful to heat the entire glass panel by playing the heat gun over the entire surface so that it would expand uniformly.
    Robert Gerlach - Antwoord
    I just broke mine during the heating process as well…. The glue at the corner was so strong that I cant even slip a blade into the edge… Then when keep applying heat using a hair dryer at low tempreture the glass expanded too much and broke……
    C Y Wong - Antwoord
    If you have never done this repair, YOU WILL SHATTER THE SCREEN! I've repaired dozens of these over the last several years for my client's and I still shatter them. It's a 98% probability that you will break the glass; it's very thin and shatters easily. Be prepared.
    Gregg Stanley - Antwoord
  2. Microsoft Surface Pro 3 Headphone Jack Replacement: stap 2, afbeelding 1 van 2 Microsoft Surface Pro 3 Headphone Jack Replacement: stap 2, afbeelding 2 van 2
    • Use a suction cup or an iSclack to pull up on the glass and create a slight gap between the glass and the metal frame.
    • If your display is badly cracked, a suction cup may not adhere. It may help to first cover the display with a layer of packing tape. Alternatively, you can superglue your suction cup to the display.
    • Carefully insert an opening pick into the gap between the screen and the device to cut the adhesive.
    • Slide the pick around the sides and bottom of the display to cut the adhesive. Apply more heat as needed.
    • Work carefully—the glass is thin and will crack easily if you try to force it.
    • The wi-fi antennas are glued under the screen border along the top edge (on either side of the camera), and can be damaged easily. Use extra care when separating the top edge, and apply more heat if necessary.
    Be very very careful!! Don’t cut yourself. Wear gloves.
    Vincent van Mens - Antwoord
    Wear eye protection too!
    Zach - Antwoord
  3. Microsoft Surface Pro 3 Headphone Jack Replacement: stap 3, afbeelding 1 van 3 Microsoft Surface Pro 3 Headphone Jack Replacement: stap 3, afbeelding 2 van 3 Microsoft Surface Pro 3 Headphone Jack Replacement: stap 3, afbeelding 3 van 3
    • Continue to heat sections of the screen with the heat gun.
    • As you make your way around the screen with the heat gun, use the plastic opening tool and the opening picks to pry the screen loose.
    • The screen is extremely thin and very easy to break. Be careful working with broken glass.
    I used an inexpensive variable heat gun with a dial. It was perfect. My fixed temperature gun would have ruined it. There are two small vents on either side of the screen near the top. Start there and work down on each side. I didn’t have opening picks to keep the glass separated from the body. So, I used blank Cards Against Humanity I found lying around.
    I watched two popular videos. Neither helped and were no better than these instructions. In one video, the guy heats and smashes his way around the display with metal tool. Mistake! Don’t do this even if the screen is broken. This causes glass shards to go everywhere and will force you to replace the adhesive before installing a new screen. You can’t reuse adhesive if it is full of glass. Another video uses a heat gun one side at a time and simply sliding a pick along the edge working around the Surface. This didn’t work. The person had already removed the screen once before and started the second removal before the video.
    CAUTION: if you insert the picks too far, you risk damaging the display (separating the glass from the display circuitry).
    The display circuitry is 14 mm from the side edges, 10 mm from the top edge, and 6 mm from the bottom edge.
    thanks a lot for your comment
    philrillh -
  4. Microsoft Surface Pro 3 Headphone Jack Replacement: stap 4, afbeelding 1 van 2 Microsoft Surface Pro 3 Headphone Jack Replacement: stap 4, afbeelding 2 van 2
    • Lift the screen up carefully so that no wires are torn.
    This guide misses a CRUCIAL NOTE on this step.
    On this step, from Picture 1 to Picture 2 the device is rotated so the Windows logo on the glass is actually on the left hand side.
    You *must* rotate the device otherwise you will risk damaging the cables, as it folds open like a book.
    Len Demby, Jr. - Antwoord
    Pain in the ass! One has to wonder why they couldn’t use magnetic connections instead of this goo, black thing that even to replace is so %#*@ annoying to say the least! After trying to remove a broken screen I didn’t even use the adhesive strips. I used the ones I had there and to be frank it’s better since:
    a) I couldn’t get the new screen properly aligned and to fit to perfection even though the touch works flawlessly (w/ some adhesive tape on the top to hide the gaps) and
    b) who knows? you may as well need to reopen it again. Hopefully not.Hopefully it will be easier. Hopefully never again!!!
    P.S.:
    Iraklis - Antwoord
  5. Microsoft Surface Pro 3 Headphone Jack Replacement: stap 5, afbeelding 1 van 2 Microsoft Surface Pro 3 Headphone Jack Replacement: stap 5, afbeelding 2 van 2
    • Remove the 3 mm T3 Torx screw securing the battery connector, and disconnect the battery connector.
    • Be careful not lose the small, rectangular bridge connector that lies underneath.
  6. Microsoft Surface Pro 3 Headphone Jack Replacement: stap 6, afbeelding 1 van 3 Microsoft Surface Pro 3 Headphone Jack Replacement: stap 6, afbeelding 2 van 3 Microsoft Surface Pro 3 Headphone Jack Replacement: stap 6, afbeelding 3 van 3
    • Remove the single 4 mm T3 Torx screw securing the display cable.
    • Lift the connector to disconnect the cable.
    It's always best to disconnect the battery before disconnecting the display cable. Ensuring there is no power to the device will also ensure you don't damage the backlight components when disconnecting the display. You should also make sure to reattach the display cable before reattaching the battery cable when putting it back together.
    KCrepairguy - Antwoord
    There is also a tiny little board between the ribbon cable and motherboard. Be sure not to lose it!!! If you do the part is 1631 LCD Contact Shield Plate.
    Joseph Neilson - Antwoord
    You’ll notice a spring on the back of your old screen. The new screens don’t have that spring so it will need to be transferred over by the heat gun trick.
    Thierry Plouchart - Antwoord
    The instructions do not mention the bridge connectors under the connectors - tiny little rectangle boards with gold connector dots. There is one under the battery connector and under the display connector. It is sandwiched in between the board and the connector. You may not even notice the bridge connectors. In fact the pictures here with the cable connectors off are showing the bridge connectors under the cable connectors still lying on the motherboard. Go ahead and remove the bridge connectors with tweezers. These connectors are just lying on the motherboard and WILL FALL OFF getting lost without noticing it. The cable connectors do not work without the bridge connectors installed. Good news is the connectors are keyed and fit only one way.
    BTW: Both screws on the battery and display connector were T3’s and the same size.
    Hi!. What’s the name of the band connector and what’s the name of the connector in both sides?
    Nicolás Rearte - Antwoord
  7. Microsoft Surface Pro 3 Headphone Jack Replacement: stap 7, afbeelding 1 van 3 Microsoft Surface Pro 3 Headphone Jack Replacement: stap 7, afbeelding 2 van 3 Microsoft Surface Pro 3 Headphone Jack Replacement: stap 7, afbeelding 3 van 3
    • Grasp the orange cable connected to the silver connecter.
    • Carefully lift the orange cable up until the connecter pops off.
    • The screen will now be completely disconnected.
    • The replacement display may not include all the parts needed for installation. Save all the parts from the original display, and transfer them to the new display as needed.
  8. Microsoft Surface Pro 3 Headphone Jack Replacement, Headphone Jack: stap 8, afbeelding 1 van 2 Microsoft Surface Pro 3 Headphone Jack Replacement, Headphone Jack: stap 8, afbeelding 2 van 2
    • Remove the single 4 mm T5 Torx screw.
    • Remove the four 4 mm T3 Torx screws.
    • Remove the single 7 mm T3 Torx screw.
  9. Microsoft Surface Pro 3 Headphone Jack Replacement: stap 9, afbeelding 1 van 1
    • Remove the nut with the 4mm nut driver.
  10. Microsoft Surface Pro 3 Headphone Jack Replacement: stap 10, afbeelding 1 van 2 Microsoft Surface Pro 3 Headphone Jack Replacement: stap 10, afbeelding 2 van 2
    • Use the plastic opening tools to remove the black piece.
  11. Microsoft Surface Pro 3 Headphone Jack Replacement: stap 11, afbeelding 1 van 1
    • Carefully remove the gray headphone jack.
  12. Microsoft Surface Pro 3 Headphone Jack Replacement: stap 12, afbeelding 1 van 1
    • Use the metal spudger to remove the black ribbon wire from the device.
  13. Microsoft Surface Pro 3 Headphone Jack Replacement: stap 13, afbeelding 1 van 1
    • Remove the two 4 mm T3 Torx screws.
  14. Microsoft Surface Pro 3 Headphone Jack Replacement: stap 14, afbeelding 1 van 2 Microsoft Surface Pro 3 Headphone Jack Replacement: stap 14, afbeelding 2 van 2
    • Finish removing the headphone jack using the metal spudger.
Conclusie
4 andere personen hebben deze handleiding voltooid.
Erik Snyder
5.221 Reputatie
5 handleidingen geschreven
Cal Poly, Team 12-18, Maness Fall 2015 Lid van Cal Poly, Team 12-18, Maness Fall 2015
CPSU-MANESS-F15S12G18
5 Leden
31 handleidingen geschreven
Één opmerking
Very good instructions. But where is the difference between Headphone Jack Assembly with P/N
0801-35U00QS, 0801-35U01QS and 0801-2W900QS? On some of them is also X894488-001 printed in an extra row.
Daniel - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 14
Altijd: 7,252
