Ga door naar hoofdinhoud
Microsoft Surface Pro 2 Motherboard Replacement
Wat je nodig hebt
    1. Microsoft Surface Pro 2 Motherboard Replacement, LCD Display: stap 1, afbeelding 1 van 2 Microsoft Surface Pro 2 Motherboard Replacement, LCD Display: stap 1, afbeelding 2 van 2
      • To avoid electrical shocks, unplug and turn off your Surface Pro 2 before proceeding.
      Vraag FixBot
      Voeg opmerking toe
    2. Microsoft Surface Pro 2 Motherboard Replacement: stap 2, afbeelding 1 van 1
      • Avoid any skin or eye contact with the heating pad or heating gun because they may cause bodily harm.
      • Using a heating pad or heating gun, heat the edges of the screen to soften the glue. This area extends roughly one inch from the edge of the device.
      • The glue is under the darker border of the device display.
      Vraag FixBot
      Voeg opmerking toe
    3. Microsoft Surface Pro 2 Motherboard Replacement: stap 3, afbeelding 1 van 1
      • Using a plastic opening tool and a suction cup as needed for leverage, gently insert one edge of the opening tool under the corner of the screen.
      • If the tool does not easily slide under the screen, return to heating before proceeding.
      • Slowly work the tool around the entire edge of the screen.
      Vraag FixBot
      Voeg opmerking toe
    4. Microsoft Surface Pro 2 Motherboard Replacement: stap 4, afbeelding 1 van 3 Microsoft Surface Pro 2 Motherboard Replacement: stap 4, afbeelding 2 van 3 Microsoft Surface Pro 2 Motherboard Replacement: stap 4, afbeelding 3 van 3
      • Detach the orange cables that connect the screen to the motherboard by pulling on the small tabs. Using the nylon spudger, release these cables.
      • Please note the third small connector in red.
      • Allow the glue to cool before letting it come into contact with any other surface.
      Vraag FixBot
      Voeg opmerking toe
    1. Microsoft Surface Pro 2 Motherboard Replacement, Motherboard: stap 5, afbeelding 1 van 3 Microsoft Surface Pro 2 Motherboard Replacement, Motherboard: stap 5, afbeelding 2 van 3 Microsoft Surface Pro 2 Motherboard Replacement, Motherboard: stap 5, afbeelding 3 van 3
      • Make sure that the front-facing camera is completely disconnected, and then remove the plastic bracket.
      • Remove the 22 screws on the bezel.
      • Remove the left and right brackets; the left has 16 screws and the right has 15 screws.
      • The three different torx screws used are T3, T4, and T5.
      Vraag FixBot
      Voeg opmerking toe
    2. Microsoft Surface Pro 2 Motherboard Replacement: stap 6, afbeelding 1 van 3 Microsoft Surface Pro 2 Motherboard Replacement: stap 6, afbeelding 2 van 3 Microsoft Surface Pro 2 Motherboard Replacement: stap 6, afbeelding 3 van 3
      • Once the brackets are removed, set them aside.
      • The motherboard itself also has screws.
      • Remove the 25 screws of varying sizes that attach the motherboard to the back plate.
      • View the attached photo of a screw diagram to help keep track of your screws.
      Vraag FixBot
      Voeg opmerking toe
    3. Microsoft Surface Pro 2 Motherboard Replacement: stap 7, afbeelding 1 van 3 Microsoft Surface Pro 2 Motherboard Replacement: stap 7, afbeelding 2 van 3 Microsoft Surface Pro 2 Motherboard Replacement: stap 7, afbeelding 3 van 3
      • You have now completely removed the motherboard, and it should look like the pictures shown.
      • Be sure to be cautious with all the connections with the cables on the motherboard.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
Christopher Doyle
131 Reputatie
1 Handleiding geschreven
USF Tampa, Team 6-2, Remmell Fall 2016 Lid van USF Tampa, Team 6-2, Remmell Fall 2016
USFT-REMMELL-F16S6G2
4 Leden
11 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 5
Afgelopen 7 dagen: 15
Afgelopen 30 dagen: 107
Altijd: 7,606
