Ga door naar hoofdinhoud
Microsoft Surface Pro 2 Audio Ports Replacement
Wat je nodig hebt
  1. Microsoft Surface Pro 2 Audio Ports Replacement, LCD Display: stap 1, afbeelding 1 van 2 Microsoft Surface Pro 2 Audio Ports Replacement, LCD Display: stap 1, afbeelding 2 van 2
    • To avoid electrical shocks, unplug and turn off your Surface Pro 2 before proceeding.
    Vraag FixBot
    Voeg opmerking toe
  2. Microsoft Surface Pro 2 Audio Ports Replacement: stap 2, afbeelding 1 van 1
    • Avoid any skin or eye contact with the heating pad or heating gun because they may cause bodily harm.
    • Using a heating pad or heating gun, heat the edges of the screen to soften the glue. This area extends roughly one inch from the edge of the device.
    • The glue is under the darker border of the device display.
    Vraag FixBot
    Voeg opmerking toe
  3. Microsoft Surface Pro 2 Audio Ports Replacement: stap 3, afbeelding 1 van 1
    • Using a plastic opening tool and a suction cup as needed for leverage, gently insert one edge of the opening tool under the corner of the screen.
    • If the tool does not easily slide under the screen, return to heating before proceeding.
    • Slowly work the tool around the entire edge of the screen.
    Vraag FixBot
    Voeg opmerking toe
  4. Microsoft Surface Pro 2 Audio Ports Replacement: stap 4, afbeelding 1 van 3 Microsoft Surface Pro 2 Audio Ports Replacement: stap 4, afbeelding 2 van 3 Microsoft Surface Pro 2 Audio Ports Replacement: stap 4, afbeelding 3 van 3
    • Detach the orange cables that connect the screen to the motherboard by pulling on the small tabs. Using the nylon spudger, release these cables.
    • Please note the third small connector in red.
    • Allow the glue to cool before letting it come into contact with any other surface.
    Vraag FixBot
    Voeg opmerking toe
  5. Microsoft Surface Pro 2 Audio Ports Replacement, Motherboard: stap 5, afbeelding 1 van 3 Microsoft Surface Pro 2 Audio Ports Replacement, Motherboard: stap 5, afbeelding 2 van 3 Microsoft Surface Pro 2 Audio Ports Replacement, Motherboard: stap 5, afbeelding 3 van 3
    • Make sure that the front-facing camera is completely disconnected, and then remove the plastic bracket.
    • Remove the 22 screws on the bezel.
    • Remove the left and right brackets; the left has 16 screws and the right has 15 screws.
    • The three different torx screws used are T3, T4, and T5.
    Vraag FixBot
    Voeg opmerking toe
  6. Microsoft Surface Pro 2 Audio Ports Replacement: stap 6, afbeelding 1 van 3 Microsoft Surface Pro 2 Audio Ports Replacement: stap 6, afbeelding 2 van 3 Microsoft Surface Pro 2 Audio Ports Replacement: stap 6, afbeelding 3 van 3
    • Once the brackets are removed, set them aside.
    • The motherboard itself also has screws.
    • Remove the 25 screws of varying sizes that attach the motherboard to the back plate.
    • View the attached photo of a screw diagram to help keep track of your screws.
    Vraag FixBot
    Voeg opmerking toe
  7. Microsoft Surface Pro 2 Audio Ports Replacement: stap 7, afbeelding 1 van 3 Microsoft Surface Pro 2 Audio Ports Replacement: stap 7, afbeelding 2 van 3 Microsoft Surface Pro 2 Audio Ports Replacement: stap 7, afbeelding 3 van 3
    • You have now completely removed the motherboard, and it should look like the pictures shown.
    • Be sure to be cautious with all the connections with the cables on the motherboard.
    Vraag FixBot
    Voeg opmerking toe
  8. Microsoft Surface Pro 2 Audio Ports Replacement, Audio Ports: stap 8, afbeelding 1 van 2 Microsoft Surface Pro 2 Audio Ports Replacement, Audio Ports: stap 8, afbeelding 2 van 2
    • The entire assembly can be removed by taking out one final screw.
    • These screws as well as the ribbon were removed during the perquisite guide for removing the motherboard.
    Vraag FixBot
    Voeg opmerking toe
Conclusie
Mathew B
323 Reputatie
2 handleidingen geschreven
USF Tampa, Team 6-2, Remmell Fall 2016 Lid van USF Tampa, Team 6-2, Remmell Fall 2016
USFT-REMMELL-F16S6G2
4 Leden
11 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 10
Afgelopen 30 dagen: 45
Altijd: 1,826
