Ga door naar hoofdinhoud
Microsoft Surface Headphones Motherboard Replacement
Wat je nodig hebt
  1. Microsoft Surface Headphones Motherboard Replacement, Motherboard: stap 1, afbeelding 1 van 2 Microsoft Surface Headphones Motherboard Replacement, Motherboard: stap 1, afbeelding 2 van 2
    • Firmly grasp the ear cushions and rotate them counterclockwise, about 45 degrees, until you hear a "click."
    • To replace the motherboard, you only need to remove the right cushion, labeled with an "R" on the headband.
  2. Microsoft Surface Headphones Motherboard Replacement: stap 2, afbeelding 1 van 1
    • Use a Phillips #00 screwdriver to remove the three 2.6 mm screws securing the right speaker housing to the chassis.
  3. Microsoft Surface Headphones Motherboard Replacement: stap 3, afbeelding 1 van 1
    • Lift the speaker housing away from the chassis, taking care not to damage the motherboard connections.
    • Desolder the two speaker motherboard connections.
    • Desoldering and soldering are delicate procedures, and there is a potential for device damage.
  4. Microsoft Surface Headphones Motherboard Replacement: stap 4, afbeelding 1 van 1
    • Desolder the red and black speaker connections.
  5. Microsoft Surface Headphones Motherboard Replacement: stap 5, afbeelding 1 van 1
    • Desolder the 23 connections from the motherboard.
    • Before soldering the connections to your new motherboard, be sure to pay close attention to which wire goes where; they're very easy to mix up.
  6. Microsoft Surface Headphones Motherboard Replacement: stap 6, afbeelding 1 van 1
    • Use a Torx screwdriver to remove the four screws.
    • Lift the motherboard up and out of the chassis.
Conclusie
4 andere personen hebben deze handleiding voltooid.
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 7
Afgelopen 30 dagen: 35
Altijd: 1,027
