Ga door naar hoofdinhoud
Microsoft Band Screen Frame Replacement
Wat je nodig hebt
    1. Microsoft Band Screen Frame Replacement, Screen Frame: stap 1, afbeelding 1 van 1
      • To avoid burning your hands, make sure to hold only the thin edges of the iOpener.
      • Heat the iOpener. Instructions on how to do this can be found here: iOpener Instructions
      • Firmly press the frame of the band against the iOpener, and hold it in place for about 90 seconds.
      • When using the iOpener, make sure to wrap it partially around the sides.
      Vraag FixBot
      Voeg opmerking toe
    2. Microsoft Band Screen Frame Replacement: stap 2, afbeelding 1 van 1
      • Using a spudger, lightly press upwards against one corner of the frame, then the other along the corner of the short edge.
      • Alternating between the same two corners, continue pressing until there's about a 1-2 mm gap between that end of the frame and the body.
      Vraag FixBot
      Voeg opmerking toe
    3. Microsoft Band Screen Frame Replacement: stap 3, afbeelding 1 van 2 Microsoft Band Screen Frame Replacement: stap 3, afbeelding 2 van 2
      • Do not pull the frame away too quickly. The screen may be stuck to the frame, and pulling on it could cause damage. If the screen is still attached, lightly push on the screen with a finger and it should pop out.
      • Insert the spudger into the gap under the frame, and lightly slide it about 3/4 of the way down one of the long edges, then repeat with the other.
      • If the frame doesn't simply pop off, try sliding the spudger the rest of the way down the long edges, and lightly lift the frame with your fingers.
      • When re-assembling, make sure the frame's microphone hole is on the same side as the sensor board underneath.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
Alan Robison
194 Reputatie
1 Handleiding geschreven
Cal Poly, Team 17-34, Amido Winter 2015 Lid van Cal Poly, Team 17-34, Amido Winter 2015
CPSU-AMIDO-W15S17G34
4 Leden
60 handleidingen geschreven
2Gids Commentaar
Where do you purchase the new screen frame? I can't seem to locate where to purchase the replacement parts.
TImmyk - Antwoord Deel
Where can I get band 2 screen cover or just parts?
Alex - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 22
Altijd: 1,389
