Ga door naar hoofdinhoud
Microsoft Band Battery Replacement
Wat je nodig hebt
    1. Microsoft Band Battery Replacement, Battery: stap 1, afbeelding 1 van 1
      • Unscrew both side panel 2mm screws using the T3 Torx screwdriver.
      Vraag FixBot
      Voeg opmerking toe
    2. Microsoft Band Battery Replacement: stap 2, afbeelding 1 van 1
      • Firmly pry up the side panel using the plastic spudger to break the waterproof seal and lift the battery panel.
      Vraag FixBot
      Voeg opmerking toe
    3. Microsoft Band Battery Replacement: stap 3, afbeelding 1 van 1
      • Gently pry up one edge of the battery with the plastic spudger.
      Vraag FixBot
      Voeg opmerking toe
    4. Microsoft Band Battery Replacement: stap 4, afbeelding 1 van 1
      • Remove battery from its compartment with your fingers.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
To reassemble your device, follow these instructions in reverse order. Replace the vibrator in its original compartment.
5 andere personen hebben deze handleiding voltooid.
Monique Salinger
408 Reputatie
2 handleidingen geschreven
Cal Poly, Team 17-34, Amido Winter 2015 Lid van Cal Poly, Team 17-34, Amido Winter 2015
CPSU-AMIDO-W15S17G34
4 Leden
6 handleidingen geschreven
5Gids Commentaar
where can i buy the battery?
chirac - Antwoord Deel
From what I can tell it's something like this:
http://www.alibaba.com/product-detail/Ho...
which is a 3.7v flat lithium ion polymer 72mAh battery. Min order is 1030 though! You can find similar on AliExpress if you search for that description. The dimensions are listed as 4*14.8*21.5mm so it'll need to be within that, or maybe the OP can confirm the battery size?
Simon - Antwoord Deel
Will this be dangerous?
Rei zzstu Shiozawa - Antwoord Deel
Anyway to upgrade to a higher capacity battery to get better life out of it? With GPS on, it dies in 2 hours and I go on 8 hr hikes.
Chris Green - Antwoord Deel
No tak wszystko fajnie ale gdzie te akumulatory zakupić ?
Tomasz Sot - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 12
Afgelopen 30 dagen: 55
Altijd: 12,586
