Inleiding
Muffled sound? Distorted sound? No sound? No problem! Simply use this guide to regain awesome audio in your projector. To follow this guide, you should have the following parts handy:
Wat je nodig hebt
Flip the projector onto its back and unscrew the nine 15mm screws using the Phillips #0 screw driver.
Locate the 2 screws on the handle casing. These screws are mirrored on the handle attachment on the other side panel as well.
Unscrew the two 16mm screws using the Phillips #0 screw driver. Repeat for the opposite side panel.
Locate the two speaker wires connected to the sound and audio motherboard on the left panel opposite of the speaker. Unsolder these connections with a soldering iron.
Once the wires are disconnected, in order to fully remove the speaker you may need to cut the plastic bands holding the speaker wires in place.
