Deze versie kan foutieve bewerkingen bevatten. Schakel over naar de recentste gecontroleerde momentopname.
Wat je nodig hebt
Deze stap is niet vertaald. Help het te vertalen
To access the OVP relay you'll need to remove the passenger side kick panel. See the guide on this process.
Look up inside below the dash, just beneath the furthest right side dash vent. You'll see the OVP relay with the red ruse on top.
Even if you are just checking the fuse, the easiest way to get access is to remove the entire relay. Simply pull it up and off of the black plug it is attached to, which sits beneath it.
This is the OVP relay out from under the dash.
The fuse on top slides in side-ways. It is a 10 amp fuse.
You can use a needle nose pliers to pull the fuse out of the holder that is attached to the relay.
As you can see here, the fuse was blown. The filament is broken internally.
Since this was the case, the fuse was replaced. The tachometer returned to normal function indicating that the fuse was the problem.
If the fuse continues to blow, the OVP relay may need to be replaced. If the fuse is not blow, you may need to test and/or replace the OVP relay.
5 andere personen hebben deze handleiding voltooid.
3 opmerkingen
Hi guys just want to know what amp's are the 2 fuses
By the relay under the hood..thanks in advance
Hopefully this is my issue. I live in the San Joaquin Valley in California and my 1981 Mercedes 240d is my daily driver. The compressor was working but we are trying to get the auxiliary fan to come on when the AC comes on otherwise it doesn't cool properly. I replaced the radiator fan with an electric and didn't realize the auxiliary fan is not working so the AC would only start cooling when the electric radiator fan would kick on. When we were trying to see how to jump from the AC relay to the auxiliary fan relay we must have over charged the system and tripped the fuse because now the compressor won't engage.
