Ga door naar hoofdinhoud
Mercedes W123 Fuel Sending Unit Replacement
Wat je nodig hebt
    1. Mercedes W123 Fuel Sending Unit Replacement, Fuel Sending Unit: stap 1, afbeelding 1 van 1
      • Before being able to proceed you will need to remove the first aid box. This guide does not cover this step, but basically, when you remove the first aid kit you will see several Phillips screws in the bottom of the box. Remove those and the first aid box lifts out.
      Vraag FixBot
      Voeg opmerking toe
    2. Mercedes W123 Fuel Sending Unit Replacement: stap 2, afbeelding 1 van 1
      • With the box out, you will see the top of the sending unit where it screws in to the fuel tank.
      • On top of the sending unit is a large black plastic plug for the wiring that goes to the fuel gauge. Start by removing this (not pictured) by pulling straight up on it.
      Vraag FixBot
      Voeg opmerking toe
    3. Mercedes W123 Fuel Sending Unit Replacement: stap 3, afbeelding 1 van 2 Mercedes W123 Fuel Sending Unit Replacement: stap 3, afbeelding 2 van 2
      • Use your large socket (1 and 13/16") and a ratchet to unscrew the fuel sending unit.
      • Optionally, you can use a large adjustable wrench or channel locks though when using tools like this there is always the potential for damaging the top of the fuel sending unit. Having the correct size socket is always preferable.
      Vraag FixBot
      Voeg opmerking toe
    4. Mercedes W123 Fuel Sending Unit Replacement: stap 4, afbeelding 1 van 3 Mercedes W123 Fuel Sending Unit Replacement: stap 4, afbeelding 2 van 3 Mercedes W123 Fuel Sending Unit Replacement: stap 4, afbeelding 3 van 3
      • You can now begin to pull the fuel sending unit out. Do it slowly.
      • Before removing it all the way, let the fuel in the unit drain out. You should hear it slowly draining as you pull it up. The more fuel that is in your tank the longer it will take to drain the unit.
      • Once it's drained you can remove it all the way to service it or to proceed at installing your replacement part.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
15 andere personen hebben deze handleiding voltooid.
Nicolas Siemsen
40.529 Reputatie
79 handleidingen geschreven
Master Techs Lid van Master Techs
Community
334 Leden
4.508 handleidingen geschreven
6Gids Commentaar
while soundproofing my 84 300d i removed the box and covered the hole with sheet metal. thanks to you i will be removing the metal and trying to remember if i kept the box. the lid was already missing. good stuff thanks p.s. i think i will weld a 1/2" drive socket onto my 1 13/16" socket. i have extras
Chris Yeyna - Antwoord Deel
11.2.16
For Diesel cars, the sender often has fungus lurking inside it and it's easy to take apart and clean if *VERY*DELICATE* .
Use some small delicate pliers to pinch the soft plastic surround protecting the special nut and unscrew it then it all comes apart easily .
Work over a clean light colored cloth and use electro - contact cleaner or aerosol starting fluid to clean the funky black fungus ~ you need to get every bit of it out, use a soft toothbrush on the bottom part .
Test easily by tipping the sender up and down with the plug attached and the key on .
-Nate
vwnate1 - Antwoord Deel
My car has been sitting for 9 years and they're sending unit isn't working or the gas gauge does not work. What should I check for first.
Craig - Antwoord Deel
God pm sir.how much is fuel sending unit for 123/300d
Edgar F Arabia - Antwoord Deel
Sable Quisiera donde lleva el tiempo de temperatura mercedes ben 280e 1981
Hugo Uribe - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 7
Afgelopen 7 dagen: 32
Afgelopen 30 dagen: 142
Altijd: 21,274
